Question about PfaFF Creative 7570
The tension is to tight on my bobbin - PfaFF Creative 7570
    Champion:
    Habit-Forming:
  • 201 Answers
Hai. Tension is to tight on your bobbin? If yes, First you change the bobbin case. Because when you stitch is not properly and not finishing.
Posted on Apr 18, 2014
Lower thread tension too loose
sorry without knowing your MAKE machine I can suggest nothing helpful
Aug 28, 2016 | Sewing Machines
Elastic thread pulled too tight in Janome Sewist 525S
I would say your tension spring is shot on your tension assembly. replace it.
Mar 27, 2017 | Janome Sewist 525S Mechanical Sewing...
Bottom stitch is gathering, but I think the machine is not threaded correctly
I would start by re winding your bobbin and making sure that it is done though all the correct tension loops. A bobbin that is wound to tight or loose can cause all sorts of problems. If that has been done then completely rethread the machine from scratch. Now go through and check all your tensions, it sounds like the bobbin tension is too loose and your stitch tension is too tight. Adjust and try again.
Good luck
Feb 12, 2014 | Euro-Pro Shark Mini Mechanical Sewing...
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
Good day!
Jun 07, 2011 | Brother CS-6000
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
Bobbin issues
Take out your bobbin case... there should be a small screw fixture on the side of the case...turn screw anti clockwise until you get the correct tension ... To test the bobbin thread tension...Remove the bobbin case keeping bobbin attached and hold it by suspending it by the thread...**** it once or twice, if the tension is correct the thread will unwind by about an inch or two. If it does not unwind at all...tension is too tight. If the tension is too loose it will drop too much. Goog Luck
Jun 01, 2009 | Singer 5050 Mechanical Sewing Machine
Bobbin on a Viking #1+ sewing machine
Could be the bobbin case tension is too tight--are you using a thicker thread than usual? Also, check to make sure that it is the correct bobbin for your machine--several are very similar but if not exact, will not sew properly. Also, if the thread is not evenly wound on the bobbin, there would be problems. Check to make sure the bobbin thread is threaded through the bobbin tension. It may help to tighten the top tension, but if the bobbin case tension is too tight, adjusting the top tension will not completely resolve the problem. The tension is correct when the top and bobbin threads meet in the middle of the fabric--this means that whenever you start a different project, you may need to re-adjust the tension.
Understanding Thread Tension Threads
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 19, 2017 | Husqvarna Viking 1
Sewing Machines Logo
27 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
