Question about Panasonic Audio Players & Recorders
I am ineed of a Technics Stereo Receiver circuit board diagram model.no SA-GX290
  • 2318 Answers
SOURCE: Fuse locations on Technics SA-DX930
This model It does not appear to have F2 anywhere, I've checked the service manual and could not find it nor is listed in the parts list.
Posted on May 14, 2008
SOURCE: Technics sa 400 Receiver
Checked fuses then sprayed contact cleaner on the fuses and the fuse holders. The speakers began to work correctly.
Posted on May 29, 2009
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
Sparky2012
  • 102 Answers
SOURCE: My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Posted on Dec 04, 2009
SOURCE: i need help
Loose connection on "POWER-SUPPLY" and sometimes solder loose on "C I S BOARD" due to extreme - heat of amplifier. $137.51 repair done in 1HR as I waited at CENTURY SOUND ELECTRONICS.
Posted on Feb 01, 2010
Would I be able to connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
Yes, it is hooked up using the (cassette) tape inputs and outputs. Use the tape monitor switch on the receiver to switch the EQ in or out.
Feb 11, 2016 | Panasonic Technics Sa-dx930 A/v Stereo...
I have got a service manual for you which will help you out.Please CLICK HERE
Goodluck..
May 14, 2008 | Technics SA-DX930 Receiver
Can I use the Phono audio connection (only RCA connection unused) on my old school Technics SA-GX290 receiver in order to connect to an audio extractor so that I can have stereo sound on my new Roku ?
No you can't. The phono connection will have a built in pre-amp which amplifies the signal from Magnetic Cartridges. If you connect anything else to it, it will either damage the pre-amp or distort the signal of your device.
It's possible to get an audio switching box that can be connected to say a tape audio in jacks and safely connect it that way.
Jan 30, 2015 | RCA Audio Players & Recorders
WANT TO GET OUTPUT I.C FOR STEREO AMPLIFIER TECHNICS MODEL SA-AX540
Try Ebay or Audio Lab of Ga.
If it's a single module , it wont be cheap
May 01, 2014 | Technics SA-EX500 Receiver
Panasonic Original Technics Sa-370 Stereo Receiver Service Manual
Hi Dan,
I also have the Technics SA-730S an now its not functional. Could you please assist me.
Rozario
Dec 19, 2012 | Panasonic Original Technics Sa-370 Stereo...
My Technics SA-R330 receiver audio problem
hello,
this problem can be solve by opening the receiver and check for dry soldering on the audio section of the printed circuit board, resolder if found any.
Also check for electrolyte capacitor if they are faulty by using an ohmmeter to read the faulty.
Good luck.....
May 25, 2010 | Audio Players & Recorders
A and B channels both have left speakers out.
Use a multitester to check the amps then you can find which amp it is.Under the cover youll see two boards on a aluinum plate.
Oct 26, 2009 | Technics SA-EX140 Receiver
I need a code for my Technics receiver SA-GX100 to program remote
technics codes:4007, 4008, 4026, 4045, 4073,
sony cd codes: 5001,5002,5099,5100,5101
sony vcr: 1001; 1002; 1003; 1004; 1005
good luck and vote for if it works
Aug 02, 2009 | Televison & Video
Probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Apr 24, 2008 | Audio Players & Recorders
Technics SA DA20
I have a Technics SA DA20 control receiver. I was given it by an electronics workshop and it has this same error of OVERLOAD coming into the display when switched on. I removed the plates from underneath and re-soldered as far as I could all the points along the stereo amplifier ICs and as far as access would allow. The unit then worked normally for several hours. I was very pleased, and went out shopping!. But on my return after it had been off for about an hour, the same problem has come back. But my boss at the electornics workshop thinks it it just a dry joint, or series of dry joints. The unit is complex to dismantle, so patience and care is required in taking it apart and making a note or diagram of how it comes to pieces and how to re-assemble it after the board has been re-soldered. It does not appear to be a component problem or fault with the SVI power amplifier ICs.
petertaussig33@hotmail.com
Feb 23, 2008 | Technics SA-DA10 Receiver
16 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
