Question about Stihl Garden
My stihl fs56 strimmer will not start,i have a spark & fuel new plug cleaned carb help please
.strimmer will not start new plug cleaned carb and exhaust checked wiring adjusted magneto/flywheel gap spark at plug compression seems good not sure if l&h carb screws adjusted correctly please help
  • Stihl Master
  • 1,807 Answers
If you have spark and fuel then id be looking at lack of compression.. damaged piston ring or damaged crank seal/gasket
Posted on Feb 27, 2016
4 Suggested Answers
  • 85 Answers
SOURCE: Sears weedwacker won't start 358.797150
Plug could be fouled. Make sure you have fresh fuel mix.
Posted on Aug 19, 2009
  • 582 Answers
SOURCE: Flywheel removal from TB425CS
YOU MAY HAVE TO USE A PULLER FOR THE FLYWHEEL I CAN'T SEE ANYTHING ON THE BREAKDOWN OF THE ENGINE THAT WOULD SHOW ANY THREADED HOLES FOR BOLTS TO REMOVE THE FLYWHEEL
Posted on Sep 17, 2009
Testimonial: "I think you're right about the puller for the flywheel. Thanks for the input."
wireguy212
  • 1627 Answers
SOURCE: what is the air gap adjustment (between magneto
25 thou,the width of a match package
Posted on Jul 22, 2010
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
I have an old 028 stihl av super electrical quickstop have rebuilt the carb on it put new gas new spark plug is turning over but not starting please help Dan from NY
due to age , id start by seeing if it has any spark in plug , remove plug wire and insert 1/4 bolt , arrange near by a metal bolt or other item (not handle ) and do not hold bolt near item
turn ign switch on (don't bother with choke) and pull engine over several times , observe 1/4 bolt for blue sparks (dim lights if necessary )
no spark present , trouble shoot ign system farther
spark present - remove and clean plug with good solvent
add a little bit of engine start fluid to plug hole and reinstall plug and wire , attempt to start engine , nothing - compession problem or shorted plug if it sputters but doesn't start then its a carb problem , troubleshoot carb (clean it )
Apr 14, 2015 | Stihl Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Stihl 011 av wont start
Flooded? Try a new plug, or get that one cleaned up. If it is sparking and wet, it should fire, even if it doesn't run, it should spark. Did you put the jets or the needle valves back to where they were? I think they start out at 1 1/4 turns out , then adjust the low and high. If it is fouling out with too much gas, the low speed jet is open too far.
May 07, 2010 | Oregon Scientific Complete Carburetor for...
Stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
Your carburetor needs cleaned or you need a carb. kit depending on how old the carb. parts are. If you need tips on carb. cleaning, feel free to ask.
Jim
May 30, 2009 | Echo Garden
Stihl FS 110 brush cutter loop trimmer ''weed eater'' won't start. I've changed gas and spark plugs and it still won't start. Tool is 5 years old. Help! D.W. from NC
Check the fuel filter, you are not getting fuel so therefore the spark is not getting anything. You can also take some carb cleaner and clean your carb. This is a common carb issue and it needs either a new filter(recommend) and also some carb cleaner shot through the system
May 18, 2009 | Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
STIHL FS110R weedeater won't start, does not hit at all. Cleaned plug, spark arrester and air filter, what's up? Like new!
my son flooded out my stihl weedeater, I took it had a new filter put in and it started right up. he went to use it again and now it wont start! It sat overnight and i still can start it! Any suggestions please
Mar 11, 2009 | Garden
Stihl FS85 Weedeater
I suspect carb. trouble. Is the compression OK? Look at the spark plug after trying to start it. If it is wet, you are getting too much fuel. The white smoke indicates that. You may need to overhaul the carb.
Go on the Stihl site and customer service for information.
Sep 17, 2008 | Garden
Garden Logo
87 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
