Question about HP OfficeJet 4215 All-In-One InkJet Printer
HOW TO PRINT LABELS USING HP OFFICEJET 4215 - HP OfficeJet 4215 All-In-One InkJet Printer
IB4G2008
  • 3587 Answers
SOURCE: mirror image printing on a hp 4215
ok..and what is your question?
Posted on Feb 16, 2008
  • 3 Answers
SOURCE: hp officejet 4215 all in one printing very light black ink, new cartridge
you must change your printer settings to the default settings.
Posted on Dec 03, 2008
SOURCE: Scan using the HP OfficeJet 4215 Printer
The problem is with Windows Vista...it does not recognize the scan button when you touch it on the scanner. There are two ways around this:
Go to Programs / Windows Fax & Scan / Click new scan / click file and then click scan
OR
Go to Accessories / Paint / Cick File /click from scanner or camera / click scan
Posted on Jan 17, 2009
jagesar
  • 9 Answers
SOURCE: New HP CP2025 printer prints "ghost" DVD circles between labels
hi, i work for a company who is the dealar of hp products.
you have to do a clean service of your hp printer.
after that the printer should not have ghost print any more.
Posted on Apr 17, 2009
  • 39 Answers
SOURCE: hp officejet 4215 error code 0xc09b0003
Uninstall and reinstall software and this should fix your problem
Posted on Apr 27, 2009
Hp officejet 4215 prints slow
Change the resolution or quality settings. Slow speed printing usually means its set to high resolution which is not needed for most print jobs.
Aug 04, 2012 | HP OfficeJet 4215 All-In-One InkJet...
Wont print in color it only prints black and gray
  1. Click on start and go to printers and faxes
  2. Right-click on the icon for hp officejet 4215 printer and go to printing preferences
  3. Click on the color tab
  4. There are two options print in color and print in grayscale. Choose print in color
  5. That should solve the problem
Jun 27, 2011 | HP Officejet 4215 All-in-One Color Photo...
On my HP Officejet 4215, my black cartridge doesn't print. The cartridge is nearly full.
If you haven't used the black print option, as in to print without using the color cartridges, then the black print head may be 'gummed up'.
You can try to clean the print head using the 'clean' function, which may work.
You can also try to get the print head to work by using ammonia and hot water. If the cartridge has its own print head, you can use some hot water on a paper towel and set the print head onto the soaked towel for a few minutes. After it has sat for a while, gently dab it dry with another paper towel, and try to use it. If it works, you're done. If not, you can use ammonia to try to clean the print head using the same tactics as using water. Try water first, then ammonia.
If the print head is fixed in place, you have to remove the whole assembly from the printer, and then try to clean the print head using the same method.
tom
Aug 11, 2010 | HP OfficeJet 4215 All-In-One InkJet...
HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
Oct 20, 2009 | HP OfficeJet 4215 All-In-One InkJet...
HP Officejet 4215 will not print
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Mar 29, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215
Hello sonyamac,
You can download the software directly from the manufacturer and install it without the CD. Go to www.hp.com/, find and click Software & Driver Downloads, select Download drivers and software, type officejet 4215 in the box and press enter. Select which officejet matches yours: 4215, 4215v or 4215xi (you can find that info on a label attached around your printer. Sometimes the model is only described as CXXXXA format. If that is all you got, go back to the prior page and type that model instead of officejet 4215. You should reach a page where you select which operating system you are using, click on it and on the next page you can select which software you want to download. After saving your download, just open the program, follow the installation instructions and you should be ready to print in no time. Hope this helps.
cancerags
Dec 26, 2007 | HP Officejet 4215 All-in-One Color Photo...
Label Printing Problems
Your problem seems to be due to worn out of rollers. Try a less glossy paper and you can find the difference.
Dec 12, 2007 | HP Officejet 4215 All-in-One Color Photo...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
21 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
