Question about Panasonic PV-C2061 20 in. TV/VCR Combo
No cable channels
I get no cable channels at all. Other TV's work fine on the same cable. The TV always shows "LINE" on the screen and doing channel up or down has no effect. I have tried changing settings to "CABLE" and other things. Any idea what is wrong? Is it possible this TV won't work since the switch to DIGITAL this past week or is it that I have some settings wrong?
Thanks for any help
Rich
    Problem Solver:
  • 13 Answers
You need a converter box
Posted on Jun 18, 2009
My son bought this TV and had it hooked up to a cable connection with an HDMI cable and it worked fine. He gave the TV to me and I hooked it up to a basic cable connection with no cable box. It does not...
If your TV has an On-screen Menu you should be able to access your Tuner controls. Run your auto channel scan and you should pick up your "regular channels". You may be able to de-select the odd channels and show only the ones you want to use.
Oct 03, 2011 | Westinghouse LTV32W6HD 32 in. LCD...
Unable to view TV programming on TV, able to utilize set for viewing DVD/VCR movies. Cable company says their Cable Card is 'OK' and the TV needs updates (assume software) in order to work correctly with...
U get a channel numder and menu screen do show up?Not the tv,it the incomming broadcasting signal cable plug in or the cable box itself have problems.Tries unplug,replug the tv and the cable box back in like about an hour later.The tv will reset itself to the factory setting and the cable box should upgraded it softwares.Should work now.If have the same problems,tell the cable company change the cable box or check the incomming broadcasting cable wire with another tv,see the incomming broadcasting signal cable wire,with a new cable box,see if it work.
Oct 21, 2010 | Toshiba 46HM95 46" HDTV
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Switching singnal
If you are using an antenna or regular cable without a cable box, put the tv on an analog channel. Go into the menu. Select the middle icon at the top of the screen. Go down to the TV/CABLE line. Select either TV (for antenna) or CABLE (for regular cable) on the right. Go down to AUTO CH MEMORY and press the volume+ (right arrow) button. Wait for the channel search screen to clear. Check all of your channels using the channel up button until you come back to the channel you started on.
Feb 28, 2009 | Sansui 27" TV
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
Rca 25" f27227e
when you bring the menu up on the screen one of the items will let you select cable; another item will let the set autoprogram, let it run through all the channels and it will select what channels you should receive-then you can do channel up/down.
May 08, 2008 | RCA F25432 25" TV
Toshiba D-VR650KU can't "see" digital channels
On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
Feb 21, 2008 | Toshiba D-VR650
Vertical line running through video channels 1-4
Interchange the video channels 1-4 and 5-7. Now check white vertical line in video port 5-7. Suppose you get problem remove cable television cable from tv during another two port running. These type problem occurs only when RF disturbance from cable television or video ochannel ports cable wire ground problem. I found there is no problem in tv. External source only the problem. I hope above details give you the better solution.
Aug 23, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Intermittent blue circle on display
Yes this is certaintly a strange one, as you say not all channels have it?? Ok lets try to narrow it down a bit. Do you have cable or satallite ? Is the cable or sat. connectected through the video inputs or does your TV have to be on a certain channel? ok and you say its not there when your watching a dvd? The only answer here is that you have a problem with your cable or the sat system, as the channel stays the same on whatever channel your watching while on the cable, so if you have a problem with some and not others , Your TV dosent know the differance from one channel or another, as its always on the same channel on the tv . So what does this tell you?? Theres a problem with the sat or cable reciver! Cant be the TV as I said the TV doent know the differance from one channel to another as it always stays on the same channel. Sounds like you need toi have cable come in to check the impedence and signal streinth.. now if your sying thast the tvs on locals and some do it and others dont ?? then theres outside interference causeing this problem? Good luck
Jul 25, 2006 | Panasonic CT-26WX15 26" TV
Panasonic PV-C2061 20 in. TV/VCR Combo Logo
223 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
