Question about Keurig Elite B40 Coffee Maker
Black and decker CM4000S clock keeps resetting itself and random brewing
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Black and decker is notorious for poor quality and troubled products....
Posted on Apr 15, 2014
Black & Decker 12 cup programmable seems to have ghosts
There is an issue in your main control board which requires a capable tinker to change out using a good one cannibalized from another identical coffee maker. Virtually all models of B&D coffee makers are sold for parts on eBay, but finding the capable tinkerer is the harder part.
Apr 15, 2014 | Black & Decker Coffee Makers & Espresso...
My black and decker coffee pot wont brew everything seems to be fine all the lights and the clock work but when i push on it wont start brewing
There is a momentary contact switch that is probably. You gran get one at the mfr. or maybe locally. When you press the brew button, you should hearing it engage . That would be a sound and a click like something has connected. If there is no sound, then your momentary contact switch is bad. Not too expensive. Probably a 5-10 minute job.
Feb 02, 2013 | Applica Black And Decker 12 Cup...
My black & decker coffee machine stop brewing coffee, sound like is going to keep working but is not .
Does the display work? Does the platter heat up when it is turned on to brew? If yes to both, this string might address the problem. Email me at the posted address if you need the part.
Jan 10, 2011 | Black & Decker Spacemaker 10-Cup Coffee...
On but won't brew
The heating element may have failed or a connection has worked loose. Chances are slim you'd find anyone even willing to look at one of these. It would cost more to repair than replace.
Apr 10, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
Black & Decker TCM800 won't go all the way through brewing cycle
I have the TCM700 and it would turn off before the brew completed.  This was because it had some sort of buildup from use.  The manual recommended to brew with white vinager and water.  The exact mix was in the manual, but my wife just did all vinager.  Worked great.
Nov 26, 2008 | Black & Decker TCM700 Coffee Maker
Spacemaker stoping before brewing pot have to keep restarting why?
If you live in an area with hard water it may just be that the calcium accumulation is preventing the water from flowing through the unit. Have you tried running a 50/50 mix of white vinegar and water through the unit? I received a completely clogged unit and then ran the same mix of vinegar and water through the unit, allowing the water to cool each time, about 6 times before completely unclogging it. Make sure to use a fresh filter each time to catch any calcium that may dislodge from the various tubes in the unit.
If cleaning the unit in this way doesn't resolve the problem, without knowing with unit you have, then it sounds like an internal thermostat is getting too hot, shutting down the internal water heater. If that's the case then B&D is using a new design for their internal thermostats, one which resets itself when it cools off, and that thermostat may be bad and kicking off at too low a water temperature in which case your only solution is to return it for exchange or replace the water heater unit.
Oct 03, 2008 | Black & Decker SpaceMaker ODC325 Coffee...
Black and Decker Coffee Maker DE790B
The warming plate is controlled by the same thermal switch that cycles while brewing and they are mechanically in contact; it switches at about 150 degrees C.  Most later coffee makers have a time limitation as well and if they are so designed, will turn off completely after 30 minutes to 2 hours after the brewing is finished to reduce the chance of the machine failing. If you insist on having one that doesn't behave this way, you can buy a cheap one from a 'dollar store,' they don't have that feature and will continue to cycle until turned off.  Your B&D isn't malfunctioning, that is how it was designed.
Sep 05, 2008 | Black & Decker (050876530606)
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
Keurig Elite B40 Coffee Maker Logo
55 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
