Question about Kyocera Mita Office Equipment & Supplies
Kyocera MFT 3500i wont print
Just moved a Kyocera 3500i mfp to a new location. It is not networked, but am trying to get it to print with usb port.
    Problem Solver:
  • 43 Answers
SOURCE: Cannot setup/connect to Kyocera CS-2050
go to kyocera mita america online. they have all the drivers. you need the KX driver
Posted on Feb 05, 2009
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
Cogz
  • 1326 Answers
SOURCE: Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Posted on Apr 16, 2009
anantakumarj
  • 330 Answers
SOURCE: Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Posted on Sep 24, 2009
shawn38
  • 200 Answers
SOURCE: kyocera will not print without kprint port
The KM-1650 will print useing a standard TCP/IP port printing over the network, I have done it ever since the machine came out. Load the print driver as a local printer and then setup a TCP/IP port and set the printer to print to that port in the printer properties.
Let me know if yo need more help.
Posted on Feb 18, 2010
How do i fix this Problem? (kyocera taskalfa 3501 ci)
Try to make pdf width some pdf creator, then check pdf and print it from Acrobat.
Oct 01, 2015 | Kyocera Office Equipment & Supplies
Why does my Kyocera FSC2126MPF print out a page with PCL XL Error on it?
It means your machine has identified an input - output error (I/O) probably receiving a corrupt data string or faulty communication port where it is connected to your computer or network. I/O ports are things like ethernet sockets, parallel ports, USB ports, and communications adapters of various types. I doubt someone is trying to fax you.
Sep 08, 2014 | Kyocera Office Equipment & Supplies
My machine shows f 248 error
F248 is communication problem ,it some times happens when the printer cannot understand the data coming from the computer from certain program's or a specific file .reset the printer clear any print jobs on the pc and try print a test page if you're still getting that error you will need to get a service engineer to upgrade to the latest firmwarec
Jul 20, 2011 | Kyocera FSC2126MFP AllInOne Laser Printer
Kyocera will not print without kprint port
Jan 15, 2010 | Kyocera Copystar Printing Systems -...
The slot where the usb cable fits into the back of the printer has 4 pins in it, one of the pins was bent and has been straightened but the print will not print. The green light flashes slowly indicating...
Well if you were using printing through usb? and now is damaged you have another options, print through network cable, or through parallel cable, and no if the usb port is damaged will not effect at all the network card or anything else.
Thanks for using Fixya
Oct 08, 2009 | Kyocera FS-920 Laser Printer
Jan 21, 2009 | Kyocera CS-2050 Black and White Copier
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Kyocera km 2050
The 2050 uses 2 network connections, one for the printer and one for the scanner.
Before I go into any great detail,
Do you have a home network? Are you using a switch?
Are you printing through the network connection or the USB/parallel port?
Are you trying to twain scan? Do you have the software CD for scanning.
If not, you will need to download the drivers from the Kyocera web site.
Mar 08, 2008 | Kyocera Mita KM-5035 Printer
42 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
