Question about Garden
I do not know what size cutting line I need - Garden
    Sergeant:
  • 340 Answers
Frank if its a small trimmer try 2.0mm if its any larger try 2.4mm
Posted on Apr 19, 2014
Brake Line
Cut the damaged section off with a line cutter and take it to the parts store for sizing, and brass compression fittings to attach it to the lines in the car.
Feb 24, 2014 | Cars & Trucks
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to know were the fuel line runs on a mcculloch 2014 chain saw
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Nov 30, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Try to replace fuel line craftman weedwacker 32cc/1.9c.u -trimmer-hose all rotten cant figure how to replace
You will need to get some TYGON fuel line. Match it up to the size of each fuel line, some of these trimmer use two different size lines, and remember which size went on which connection. You will want about a foot of each. Cut one end of each line at a 60 degree angle. With a pair of needle nose pliers, feed the angled end of the fuel line into the hole going into the tank and feed it into the tank untill you can see at the tank fill. You cut the angled end off and put your filter on the line. Pull it back until the filter lays at the bottom of the tank. Hook this line up to the supply side of carburetor. Take the other line and put it in the tank about 1" or 2"
then cut it off to fit on the carburetor. HTH
Good Day.
Nov 10, 2009 | Craftsman 25cc Gas Line Trimmer
I have an old 720r trimmer plus ryobi. need to replace the fuel lines. what size is needed
Im not sure on the size I always pull the old ones off and find the matching size,I will however tell you a good trick for installing new fuel lines on trimmers. Get a fine piece of metal wire about six inches long or so (like mig welding wire). You want to take the end of the new fuel line and with snips cut a 45 degree angle so it kind of comes to a point. Next poke the wire through the end you cut and twist it. Finally use the wire to pull the new line through.
Aug 09, 2009 | Garden
Fetherlight xt200 fuel line connections
Jim
Jun 27, 2009 | Poulan Garden
Fuel line for featherlite xt200
Is it possible that you have the wrong size fuel line? On this particular trimmer, there are two different sizes. If not, try this: cut the fuel line at an angle. This makes it much easier to feed through the hole. Once you have it where you want it, cut it off square again. If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Garden
18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
