Question about T-Mobile Sidekick® 3 Cellular Phone
Phone fell in the toliet
My phone fell in the toliet and i have been drying it out and it still wont work.....its very sad. I have like taken the whole thing apart and let everything dry but it wont work...and suggestions?
    Problem Solver:
  • 5 Answers
Dont take a poop with ur phone
Posted on Jun 19, 2009
Dropped my phone in water
Take as much of the outside casing apart as you can and remove battery if possible straight away then leave submerged in a bowl of rice overnight. Sounds silly but it works. Hope this helps.
Oct 19, 2012 | Pantech Pursuit P9020
My android fell into a puddle of water and now is not functionining. Blue light on in right corner
Your phone is - sadly to say - probably dead.
With older phones, one can take out the battery and leave them to dry. In some cases the phone will function again. Sadly, with the newer phones, the electronics are so sensitive that water almost always will ruin the phone.
But, you can always leave it to dry (with the battery taken out!), and if you are very lucky, your phone will function again.
Jul 23, 2011 | Motorola Lands Phones
My HTC Aria phone fell into my coffee cup. I have taken the phone apart to dry off, but there is a medium size puddle of coffee located behind the front glass that is out of my reach. Any way to get that...
One solution to try is putting the phone in a Ziploc bag along with some silica gel which absorbs moisture. It can be found for cheap online through many retailers http://www.silicagelpackets.com/silica-gel-packets is one of many options.
Other than that you can try leaving out in the sun or under a lamp and hope it dries out but without taking off the screen you don't have a whole lot of options unfortunately.
Mar 18, 2011 | HTC Aria Cell Phone
Dropped phone in toliet. touch screen wont light up and wont work.
I do this all the time, grrr. This phone is toast most likely. Take out the sim card and memory card to prevent them from corroding. The phone may dry out and return "some" functionality, but it probably won't work correctly again.
Dec 03, 2009 | HTC G1
My sidekick 08 droped in the toliet and iht wont work no more .
the best is to open it and spray the pc board with combat penetrating oil, let it dry and try it again
May 23, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Dryer gets hot spins takes several cycles to dry fully
ahhh very common, clean clean clean inside the dryer, take the lint screen put some toliet bowl cleaner on it let it sit while you are tearing the dryer apart and clean the whole dryer vent and or change it, make sure the flap outside is not stuck shut as well...
May 08, 2009 | Dryers
Dropped Pantech Matrix in water
it's probably going to be really expensive to repair it if there is major damage. but i got in the pool with my matrix in my pocket and i dried it out and it wont turn on with the battery in it(it's bad i know) but if i take it out and plug it up it works fine but i cannot call, or text. it wont connect to a network. i dont know whether or not i should invest in a battery which isn't that pricey at all or just get a new phone. i'm just not sure if a new battery will fix the problem.
May 04, 2009 | Pantech C470 Matrix Smartphone
I dropped my phone in the toliet
Try undoing the whole phone and take out the battery to dry out in the sun.
I put my daughters thru the washing machine and it came back on. Its worth a try.
Dec 21, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Dropped in toliet!
Turn it off (If it hasn't shut off already). Take the battery out. Let it sit for at least 4 hours in a warm area (about 85 F will do). The moisture needs to completely evaporate from all parts inside the phone. When the phone is dry and has had time in that warm environment to evaporate, you can put your battery back into the phone and turn it on. Depending on the level of damage done, it will either work fine, work but have glitches here and there, work on some things but not others, or not work at all. If the phone fails to turn on, take it to your local retailer and ask them to test it for functionality, and if possible, to reprogram the phone (re-install its firmware). If none of these things help, you'll have to replace your phone.
Nov 27, 2007 | Samsung SCH-a670
T-Mobile Sidekick® 3 Cellular Phone Logo
44 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
