Question about Black & Decker Coffee Makers & Espresso Machines
Black & Decker 12 cup programmable seems to have ghosts
One night i woke up to the sound of coffee brewing, despite the fact that i had not programmed the pot to do so, nor had i filled it with water or coffee (problematic). the clock said 4am, but it was really 530am. it hasn't " ghost brewed" since that night, but every time i reset the clock to the right time, a few mins to an hour later the time is all wrong. i've tried unplugging, reseting, etc. Help!
  • 29 Answers
There is an issue in your main control board which requires a capable tinker to change out using a good one cannibalized from another identical coffee maker. Virtually all models of B&D coffee makers are sold for parts on eBay, but finding the capable tinkerer is the harder part.
Posted on Aug 31, 2014
  • 19 Answers
SOURCE: Coffee doesn't brew full pot
It's possible that the hose or valve running from the tank to the heater is partly clogged. See superkev2000 and W5VSI fixes posted here.
Posted on Jan 19, 2008
  • 2039 Answers
SOURCE: Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Posted on Feb 14, 2009
SOURCE: GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Posted on Apr 03, 2009
SOURCE: black and decker spacesaver coffee maker
There are two heat stages in the Spacesaver. One is the carafe heater you can see while the other is an assembly within the main housing. This assembly contains a heater, thermostat, and a section of metal tubing with high temperature silicon connectors at each end. when the water storage tank is inserted it fills the heated section of the tube and when activated the water boils as it passes through the one way valve and forces the water into the coffee container. This steam driven surge repeats until all water has been moved to carafe. There are several failure modes associated with this assembly an I have two. 1. is the heater opening which I have and 2. is the thermostat degrading causing incomplete transfer and ultimately no transfer because it brings the temp down prematurely. Another is crud on the check valve so many problems - no solutions
Posted on Jun 01, 2009
  • 85 Answers
SOURCE: cuisinart Coffee on Demand?12-Cup Programmable Coffee
Hello crystalmeikl,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, crystalm. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 11, 2009
What can I do if my 12 cup black and decker coffee maker wont brew. Power is on
These devices are unfortunately made cheaply these days. If it is fairly new, say within 6 months, contact the manufacturers customer support line (found on documents or their website) and they often just ship you a replacement.
Otherwise, if the water is not coming out and spilling over, make sure that the release in the brew basket is opening when the pot is placed under it. Some of them stick and then the coffee overflows.
Oct 01, 2016 | Applica Black And Decker 12 Cup...
Coffee pot not working
old and tired needs replaced . this is how they die
Sep 05, 2016 | Black & Decker Black&Decker Coffee Maker -...
My black and decker coffee pot wont brew everything seems to be fine all the lights and the clock work but when i push on it wont start brewing
There is a momentary contact switch that is probably. You gran get one at the mfr. or maybe locally. When you press the brew button, you should hearing it engage . That would be a sound and a click like something has connected. If there is no sound, then your momentary contact switch is bad. Not too expensive. Probably a 5-10 minute job.
Feb 02, 2013 | Applica Black And Decker 12 Cup...
Looking for the on/off switch
I've replaced the power switch/button on a Black & Decker SmartBrew coffee maker (DCM2000).
I used an illuminated rocker switch from NTE Electronics rated at 16A @ 125 VAC, part number 54−531.
This switch cost me $3.12 CDN + taxes.
http://www.nteinc.com/switches/pdf/illuminated_rocker.pdf
The pinouts on this switch are the same as the rocker switches/power buttons used in the basic Black & Decker Smartbrew coffee makers.
You can simply cut out the old switch and attach this one to the wires in the same order, as indicated by the square notch on the body of the switch/gold terminal.
May 19, 2010 | Black & Decker Smart Brew Plus 12 Cup...
Coffee Makers & Espresso Machines Logo
146 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
