Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
Relace flush valve seal - American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
  • 25 Answers
The American Standard Cadet 3 flowise one piece toilet uses a flapper valve with a soft nylon washer to seal against the water outlet.
Over time this nylon washer develops 'puckers' causing water to seep between the nylon washer and the seat of the flapper. This seepage causes the water level in the tank to drop to a point where the water inlet valve opens to replace the lost water in the tank.
There are two ways to correct this problem:
1. Replace the soft nylon washer on the flapper, or
2. Replace the entire flapper valve.
Hope this solution helps.
Posted on Jul 27, 2015
2 Suggested Answers
snap101
  • 117 Answers
SOURCE: Flush valve drops before bowl completes flush
is the flapper weighted? if it is it will cause it to shut prematurely. one thing you can do is increase the water in the tank. you might have to buy a pvc cuppler to put on the over flow to allow it to fill up more. korky makes a nice flapper thats not weighted
Posted on Aug 01, 2009
How do I stop water running into pan after toilet has been flushed &refilled.
If there is water still running into the toilet bowl, there is a problem with your flapper or flush valve. The most common problem, and least expensive to fix, is the flapper has gone bad and is allowing water to escape past it. Replace the flapper and the water should stop running. If not, it is possible the flush valve or one of the seals holding it to the tank has gone bad and needs replaced. Try replacing the whole flush valve. They come in a kit that includes the valve, flapper, and seals.
Feb 26, 2015 | Home
Water leaks from tank to bowl all the time
It is most likely the flush valve gasket. This is the equivalent of a flapper on a normal toilet. You can purchase these seals at plumbingmall.com 750017 Outlet Valve Seal for M5 Flush Valve
Aug 06, 2013 | Caroma Sydney Smart 270 Elongated Dual...
Cistern
The arm controls the Flush Valve. Inside the flush valve is a black rubber "seal" that closes the end of the fill pipe and stops the water. If a piece of sand, grit, or small rock gets imbedded in the seal it will allow water to pass through even when the tank is full. Either you take apart the flush valve and remove the grit, or you replace the whole valve. Sometimes even when the grit is removed the rubber seal is damaged and must be replaced. A new valve, and some of these replacement seals can be purchased at a good hardware or plumbing supply store. Use the valve handle, below the tank, on the pipe that comes through the wall, to turn off the water before replacing the seal or valve.
May 26, 2013 | Home
I have a Duravit Starck 2 toilet cistern which is approximately 5 yrs old, recently water from the cistern runs constantly into the bowl. I have renewed the flush value without any success. I would...
Did you replace the flush valve or the flapper?
There must either be a problem with the seal between the two surfaces of the flapper and flush valve or the flapper is being prevented by the flush system to returning to make a seal against the flush valve after the water completes draining during the flush cycle or more likely water is draining through the overflow tube.
Make sure the sealing surfaces are clean and not damaged.
Make sure the flapper is not being interfered with and is able to return to the closed position to make a complete seal against the flush valve.
Check adjustment of the water fill level to make sure the water is not filling above the water overflow. If the inlet valve does not shut-off when the level is adjusted to the proper level the water inlet valve may need replacing.
The following videos may prove helpful.
Dec 22, 2010 | Home
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
Dec 28, 2009 | Kohler K-3489 Cimarron Comfort Height...
Water leaking between tank and bowl relaced seal on valve still have leak .Even with bolts tight tank rocks on bowl
Make sure that you have replaced ALL of the seals in the bottom of the tank. There should be one donut for the pipe itself and the two or three rubbler washers for the bolts.
Oct 20, 2009 | Kohler Cimarron 2-PC Elongated Toilet with...
White smoke comming from the tail pipe suddenly with a strange sm
if the white smoke is in the morning,only then it is valve seals and if it is through out the day as your driving the vehicle then the engine need over houling,(rings metal and main bearing in the engine need to be relace,including valve seal , top gasket,botom gasket and oil seal for proper perfomance.
Dec 05, 2008 | 2003 Volvo XC90
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
219 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
