Question about Samsung Sew-3034 Smartview Video Baby Monitor With 3.5 Inch Lcd
Samsung sew-3034 won't charge and keeps beeping
The handheld won't change. I have 4 cameras and it is too expensive to replace them all. how can I fix the charging problem?
Bajanguru
  • 7752 Answers
SOURCE: beeping
type *2767*3855#
Posted on Aug 17, 2008
wicabuss
  • 48 Answers
SOURCE: On start-up, Samsung S860 beeps 3 times then turns itself off
first off,never use rechargable batteries in this camera or most digital cameras for that matter.2 use only lithium batteries,enegizer preffered.,also yes you can view all your pictures when connecting the usb,meke sure you turn the power on,and highlight the word computer,push ok.you should be fine.good luck .i hope i helped
Posted on May 01, 2009
SOURCE: I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Posted on Jun 17, 2009
SOURCE: my samsung pl100 wont turn
OK this might sound harsh but i just did this. I pushed in, gently with some force, on the lens while pushing the power button. It made a gawd awful crunch sound, but it worked. Good luck.
Posted on Dec 30, 2010
dave_giaimo
SOURCE: My Samsung Transform Ultra phone keeps beeping as if I am plugging and unplugging the charger.
Flip the phone over after a charge. Put your fingernail into the little slot at the top center of the battery cover along the edge, and give a little twist. The batter over door will snap open a little. Grab it and remove it gently, and pull the battery out of the Transform. Count to ten, then put the battery back into the phone. Once the phone boots, the noise should be gone.
If this fixes your problem, you may have to repeat this process every time you take the device off the charger. If this does NOT fix the problem, then it is a short in your phone's MicroUSB connector that is causing the incessant beeping, and your phone will require either repair by Samsung (Boost Customer Service can give you the number), or replacement by you, with another phone of your choosing.
If you DO decide to repair or replace the phone, make sure to back up all of your data, photos, movies, notes and applications before you surrender the phone to anyone for repair or replacement. Every repair facility WILL do a factory data reset on your device before beginning to repair it, and the phone will come back to you in "new-in-box" condition, post-repair - with NONE of your info on it. Best way to back it up is to hit the Google Play store, and search "backup" - there are MANY online backup services from which to choose, and you can easily find one that will meet your needs and budget.
Posted on Aug 16, 2012
Why does my phone keep beeping when it is plugged I to charge?
It isn't being charged, either your charger or the battery is bad.
Dec 15, 2015 | Samsung Galaxy Centura 4 GB Black...
I have a Samsung baby monitor SEW-3034, it was working pretty ok, but after 2weeks not using, now when I plugged in power and turn on, only beep once and no screen show up, try charge for a long time, but...
You can connect up to 4 cameras and each camera must be paired with the monitor. Sounds like you need to repair the camera so that the monitor will recognize it. Look at the boston of the camera there should be a button to press.try this
Aug 16, 2013 | Baby Gear
Gamin 405 battery keeps going flat.
Yeah - that's a problem - you can send them back for a replacement but it's expensive.... it certainly happens - there is a definite lifetime in terms of # of charging cycles.
May 27, 2012 | Garmin Forerunner 405 Handheld GPS...
My samsung sew-3030 won't keep the current date
To update firmware you will need a Microsoft Windows based PC and download the latest firmware on this website:
http://www.samsungsecurity.com/product/product_view.asp?idx=6404.
SEW-3030_mr8911isp-nor+spi_For US.zip (2.23MB)
Once downloaded, unzip files to your desktop and do the following sequence:
1st -> RUN file Generic_V1.0.0.0.EXE (USB firmware update driver)
2nd -> connect your wireless video monitor to power adapter
3rd -> press and hold select (enter) button in the middle of the dial.
4th -> connect USB cable to your PC. (screen will blank white instead of black) this is firmware update mode
5th -> RUN firmware update utility mr8911isp.exe , wait to USB connection (status bar will turn green) and show message ASIC: 0301 Device Connected
6th -> Press Update button and wait...
7th -> Update done! disconnect your device and voila! no more date/time issues and another bonus bugs fixed noticed: lower alarm beep volume, menu text size increased for better reading, temperature sensor more reliable
I Hope it help everyone having problems with this baby monitor
Jan 03, 2012 | Samsung Wireless Security Monitoring...
My baby monitor won't charge - it's not even recognizing the charger as plugged in -- the red light doesn't go on any more??
shut it down and restart and see if it takes the charger ..usually there is nothing that makes the camera behave that way but the charger ..either being damaged or the plug does not makes contact well ..check the wire not to be damaged and try another charger with the same specs ..exactly the same ..It is possible to be damaged if you let it in the plug for a long time ..
If it shows out that the charger is not to blame ..than it is a mater of plug need to be changed cause is damaged ..In worse case just open it and hot wire if you can not get a plug to match ..
Dec 28, 2011 | Samsung Wireless Baby Monitor Camera...
My dyson handheld charges fully, but keeps cutting out when using. About 7 seconds is the longest continual usage time
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to replace the battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
May 21, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I have a unit that is about 4 years old and appears to NOT hold a charge. I know to only charge for 3 hrs max but want to be sure my problem is the $75.00 battery before I purchase one. What is your...
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Mar 09, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Samsung Sew-3034 Smartview Video Baby Monitor With 3.5 Inch Lcd Logo
59 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
