Question about Gigabyte GA-8IE Motherboard
P4 titan533 bios problem - Gigabyte GA-8IE Motherboard
    Brigadier General:
  • Gigabyte Master
  • 3,400 Answers
And what might the problem be?
Apr 15, 2014 | Antec Computers & Internet
Update bios
yes you can but newer bios dont have instant audio and instan FM radio anymore..as i remember as long time i use it as media center,and now is NAS..that old barebone..with 250W power suplly..
Jul 07, 2013 | ASUS P4-533 Terminator (terminator p4)...
I want upgrade my CPU from p4 520 to p4 660(2M L2 cache) on dimension 4700. I want to know if that will work on my pc. Right now i am operating on bios A05,and i want to know if i have to upgrade to bios...
For best results, you should run the Dell System Analyzer on your computer:
http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&l=en&cs=19&s=dhs&~ck=anavml&dgc=SM&cid=54281&lid=1472034
Updating the BIOS, while not difficult, is not usually recommended unless it will solve a problem. The reason for that is you must follow the instructions provided by the manufacturer exactly or you could render your computer useless.
If the Dell System Analyzer determines that you can upgrade to a P4 660, then go ahead and replace the P4 520. If the P4 660 doesn't work, then the best approach would be to re-install the P4 520, make sure the computer works, then update the BIOS after carefully reading and understanding all the instructions provided by Dell.
Sep 13, 2010 | Dell Dimension 4700 PC Desktop
I need ibm p4 rev 1.2 bios
dude until u give the motherboard name and info on the pc we cant help u out sorry !!
Mar 04, 2010 | IBM (03R0329) Motherboard
Hi i have a p4x266e 8233 via board i had there a 1,7 intel celeron and i switched it for a 2,4 p4 whit HT and the pc is now running at only 1,2 GHz . The p4 is woring i know that for ...
You have hit the nail on the head.
Update your BIOS and that should sort the problem out. You can always go into the BIOS and set the clock speed of the processor providing the BIOS utility supports changing the clock speed.
Regards.
Nov 12, 2009 | Computers & Internet
Intel P4 2.66GHz/512/533 is not working on MS9337C+.
#1. Does the CPU fan run if not then you may have a conductivity problem between fan and CPu. Did you use thermal paste or grease?
If fan is running follow directions below from my manual for MS9377C+ mainboard.
Go into the BIOS setup ,go to CPU setup, select proper voltage for you CPU. On Advanced setup page see if the hyperthreading function is revaeled. If so your CPU has this function. Set "Enabled " to test HT CPU function. If this doesn't work try "Disabling" the function. Good luck. I am about to attempt tp upgrade to a Prescott 3.0E which the box says this board supports. Sure hope so . Am running a 1.7 now.
umcds@sssnet.com
Apr 16, 2009 | Matsonic MS9337c Motherboard
Processor compatibility
looks like you limited to the p4 Prescott, this is a p4 list of the cpu support from asus. I also looked at their bios update page and found no bios improvement. if you can move to the 775 platform ,you can move from p4. otherwise, the p4's are still  good . I had the cpu that is the 2nd one down. 3.2ghz oc'd to 3.8ghz full time with a max of 4.0ghz on air[775 platform] quad-pumped gave me a 1001.3mhz FSB
Supports Intel Prescott CPU
P4-3.20E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   ALL 1006 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1)   ALL 1011 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:512KB, HT, D1)   ALL ALL gogo.gif
P4-3.40E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   2.00 1006 gogo.gif
P4-3E GHz (800 FSB, L2 cache:1MB, HT, 90nm)
SEE 4 YOURSELF
http://valid.x86-secret.com/show_oc.php?id=156822
Oct 30, 2007 | ASUS P4P800 SE (890552603657) Motherboard
ThinkPad A 30 upgrade to P4 1.8GHz 26P8327
If you need then do BIOS!! My advice is not do that!!! It's very risk because if you make one mistake, you can throw it!!!! :+)
Oct 19, 2007 | IBM CPU 1 8GHZ P4 26P8327
Gigabyte GA-8IE Motherboard Logo
23 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
