Question about Toshiba RD-XS35 DVD Recorder/HDD Recorder
Remote wont respond display reads dr-1 - Toshiba RD-XS35 DVD Recorder/HDD Recorder
2 Suggested Answers
  • 10865 Answers
SOURCE: I bought mu D-R2 DVR
hello inira. DR-1 and DR-3 are two separate but similar toshiba model types.
Your machine must offer both in that one machine. Your best bet is to replace the remote with a new original remote control.
here is a link where you can purchase one
http://www.replacementremotes.com/
Joe
Posted on Apr 29, 2011
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
Model DR-S2.0. Why doesn't it respond to remotes?
If your receiver does not respond to the original remote, the remote may have failed.
If your receiver does not respond to your Harmony remote, the remote may not have been programmed or may have "forgotten" what to do.
Another possibility is that the infrared receiver has failed
Feb 16, 2016 | Onkyo Audio Players & Recorders
I bought mu D-R2 DVR without original remote. Got one GE universal and just set it up and got to the main menu.And this was my 1-st time to get there.Checking settings, I changed from DR-1 to DR-3 and...
Joe
Apr 29, 2011 | Toshiba D-R2 DVD Recorder
I GET SET 1 EVERYTIME I PRESS BUTTON ON CONTROLLER
Set remote to 1 by pressing 1 holding Ok/Enter for 3-5 seconds.
Jan 30, 2011 | Panasonic DMPBD45 BluRay Player
My logitech 550 is not responding. It has worked
Hi. That message means that there is a button that is stuck down on the remote.
1. Take out the battery, push in and massage each button to ensure it is not stuck down.
2. Put the battery back in, update the firmware,
3. Update the remote.
That should get the remote working again. :)
Oct 31, 2009 | Logitech Harmony 550 Remote Advanced...
Dr 2 message
I just sorted this on my own dvd player. push HDD and DVD buttons on the front of the player together for 3+ secs. Menu will display DR-OFF. Do the same again menu will disolay DR-2. On the remote push mode and "2" together and ths will put the remote into DR-2 mode. All should now be well.
Aug 30, 2009 | Toshiba D-R2 DVD Recorder
My Toshiba SE-R0161 Remote no longer works.
There is most likely nothing wrong with your remote. I just had exactly the same issue with my SE-R0161 remote. (I had just changed my remote batteries too and was getting a DR-2 code on the Toshiba DVR RD-XS52 unit's display.) My DVR and my remote had to be realigned so that they both have the same infared (IR) code. The remote and the DVR can have DR 1, DR 2 or DR 3 as remote codes. Pg 54 of the Toshiba Installation Manual explains how to align both your SE-R0161 and your based unit so that the remote works again. Good luck. Hope this helps.
Mar 27, 2009 | Televison & Video
Toshiba RD 85DT DVD recorder
ok you need to press STAR Button which says mode above it and either 1,2 or 3 to find which freqency is being use. The dvd and the remote need to be on the smae on.
Oct 18, 2008 | Toshiba RD-XS52 DVD Recorder
Remote control
turn on the dvd player
press and hold the 'enter' key and the '1' key at the same time
remote will start to work again
Sep 14, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Toshiba RD-XS35 DVD Recorder/HDD Recorder Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
