Question about Promethean Board Lamp for PROMETHEAN PRM25 Projector
Flickering image My promethean PRM25 projector is flickering, we have cleaned color wheel and changed lamp and neither affected it. There are no warning lights being given either.
2 Suggested Answers
SOURCE: flickering
Did you check your cable? if the connection is bad the image will flicker in and out.
Posted on Oct 25, 2012
The bulb on my promethean board has been changed, and the filter has been cleaned, I cannot see the menu to reset it, how can i get it to work.
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 12, 2014 | Panasonic Projector Lamp for PT-LB60,...
Prm 25 projector
Not what you want to hear but this error means the lamp did not ignite. The most common problems I have had with projectors has always been the lamp itself, so if you have another or know someone with a good lamp try that first.
Jan 15, 2014 | Promethean Board Lamp for PROMETHEAN PRM25...
My projector has a blue flickering hint in the picture, is it a lamp related issue, or is it a lcd problem.....?My lamp do needs replacing because the indicator says so.......but will replacing the lamp...
blue flickering hint, means the lcd panel is break,
or polarizer is break. We supply original projector parts: lamp, bulb, Lcd
competitive price.
have a nice day!
Jul 12, 2013 | Epson Replacement Lamp ELPLP30 f EMP-61...
I need instructions on how to replace the lamp in the promethean prm-25 projector
Make sure projector is unplugged and cooled down, lamp can be very hot
Remove the cover over lamp area
There are 3 screws in lamp unit (they have little arrows that point to them even) or check against new lamp to make sure you take out the correct ones
Pull straight up, place new lamp in securely and screw back down (screws are attached to each lamp set)
Place cover back over lamp area and screw closed
Reset lamp hours by hooking up your computer to board
Get to lamp reset screen
Press down up left right arrows in sequence then press return button in middle
Jan 26, 2013 | Promethean Board Lamp for PROMETHEAN PRM25...
Flickering projector image
1,the color starts to go out, it become the white and black,the color is disappear.
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as 3 sesame seeds
Have a good day!
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
have a nice day!
Nov 01, 2012 | Acer X1130P 3D Ready DLP Projector...
Flickering
Oct 24, 2012 | Promethean Board Lamp for PROMETHEAN PRM25...
I have a Promethean Interactive Board in my classroom that is paired with an Epson 83C projector. The picture that is blurry. How can I focus the picture on the Promethean Board? Thanks!
the light is blerry ,
Pls check the lamp,(if it is bright enough )
check the color if it is correct and brite-colored (if the LCD panels is work well)
Have a nice day!
wheel,
Lampdeng Limited
Jerry
Oct 01, 2010 | Epson 5300 7200 7300 Replacement Lamp -...
LP600 - Grainy picture, very poor quality
Single chip DLP projectors use a spinning color wheel between the lamp and the DMD (mirror chip) to produce colors. If the wheel rotation/synchronization is disturbed, colors will not be displayed correctly.
In my case it looks like the wheel became un-synchronized, probably because the projector was dusty/dirty inside (a light senor is used to detect the wheel position), resulting in a grainy, slightly flickering image.
I simply blew out the components with a can of 'Dust-off' and, using a small tool, rotated the color wheel by hand to make sue it wasn't rubbing or jammed.
I reassembled & started the projector and the image was back to normal.
Jul 19, 2008 | InFocus LP 600 Multimedia Projector
Color
Hi, If you have tried other video sources & still get the same results. It sounds like the motor that turns the color wheel is going bad, These motor's run from 5,000 to 10,000 rpm depending on model & are usually the first point of failure in a color wheel based DLP projector, If you don't count the lamp.
Overtime it may begin to make a squealing noise. Usually you can find replacement motors on the internet by searching the part number printed on the motor google is great for searching part numbers.
Feb 19, 2008 | Optoma H31 WVGA 480P Native EDTV DLP...
Sharp Projector XV-Z90 Flickering
the color wheel is dirty. It just need to be cleaned.
Feb 18, 2008 | Sharp Projector lamp Projector Lamp
Promethean Board Lamp for PROMETHEAN PRM25 Projector Logo
50 people viewed this question
Top Promethean Board Office Equipment & Supplies Experts
FireballXL55
Gramonion
Gramonion
Level 1 Expert
Are you a Promethean Board Office Equipment and Supply Expert? Answer questions, earn points and help others
