Question about Whirlpool WED9600T / WED9600TA / WED9600TW Electric Dryer
Dryer won't tumble.
Dryer has power; light comes on/off when door is open/shut; dryer gets hot when turned on, but the dryer won't tumble. I can't hear any sounds from the dryer (humming or buzzing) when I turn it on.
  • 822 Answers
Check the belt............if ok then could be the motor ..........cheers
Posted on Apr 15, 2014
  • Bishop Christopher
    Bishop Christopher Apr 15, 2014
    How? That is the magic question...
  • 262 Answers
SOURCE: My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Posted on Jan 08, 2008
  • 958 Answers
SOURCE: whirlpool dryer won't run
you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but you said that even the motor is not running, the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Posted on Feb 06, 2008
Your dryer belt is broken. I just had the same exact problem. You need to replace the belt.
Posted on Jan 09, 2009
astruttman
  • 45 Answers
SOURCE: dryer blows house fuse --keeps tumbling--no heat
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
Now, if your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. You have to remove the entire front panel on some models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set.
Posted on Jan 11, 2009
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
My tumble drier door isn't shutting so it won't turn on?
Make sure the wall plug is hot and if it is ok then check the dryer door safety switch, if that switch fails to connect when the dryer door is closed then the dryer will not start.
Jun 30, 2017 | Dryers
Dryer won't heat up and light bulb turns on then off when door is opened.
Does the drum spin when you shut the door and start the dryer if so it wouldn't be a bad door switch. 1st. thing I would check would be the igniter with front kick panel off dryer it's located at the bottom right hand outer side of drum in the burner duct. here's how you check it with door shut start dryer and look for a orange glow from the igniter if no glow it's a bad igniter if it's not the igniter it could be a thermostat or a flame switch check these things if need more help I'll be glad to help.
Feb 25, 2013 | Dryers
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
MED9700SQ dryer sensor light comes on but will not run
I have the same problem with the same model Maytag dryer. I called a repairman and paid a hefty service charge and the repairman found that the electronic control board needed to be replaced. This particular part (Part #8558455) costs between $250 and $350. Evidently there are many people with the same problem.
Feb 02, 2013 | Maytag MED9700S Electric Dryer
Won't tumble. Drum won't roll. How do we open it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Kenmore 62702 Electric Dryer
I have a tumble dryer.
Sounds as if the door switch is the problem. This is normally a safety switch that stops the dryer when the door is opened.
Unplug the dryer.
Remove the door switch and check the switch condition with a continuity meter after removing the wires. Try turning the switch on and off....the meter should read power on and off when you do that.
You may have to remove the front of the dryer to get to the door switch.
Good luck,
I hope this helps
Oct 05, 2009 | Hotpoint Dryers
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
My hotpoint vtd20 tumble dryer will not start. I was using it then when I put a second load in and pressed start - nothing happened. The power light is on but no tumbling!
If you can hear the motor running but no tumble action then belt has come off.
Make sure the door is shut properly..
If it gets hot at the back, then you are difinately getting power to everything.
If you can hear a slight buzzing noise, then the motor is failing to start, probably due to a faulty start capacitor.
Dec 08, 2008 | Dryers
Whirlpool WED9600T / WED9600TA / WED9600TW Electric Dryer Logo
87 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
