Question about Intertherm P3RA-048K Air Conditioner
Wiring diagram for p3ra-o48k to a Hunter 40035A thermostat
How to
    Sergeant:
  • 340 Answers
Not for free
Posted on Jun 19, 2009
Need a wiring diagram for a EEH-012H intertherm
Request the wiring diagram from Hunter and, if need be, Intertherm.
Feb 12, 2018 | Hunter Heating & Cooling
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
I need to find an owners manual/wiring diagram for a Hunter model 44250A programmable thermostat.
Hope, you can get it from:
personafile.com/Hunter-Fan-Company-Thermostat-44250A-P0496942301829.htm
Dec 29, 2010 | Heating & Cooling
Need a wiring diagram for thermostat/hunter model44260
Hello please try this link and see if this contains the information that you need
Reply to bsix@hotmail one way or the other Thanks
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/42711.pdf
Sep 04, 2009 | Hunter Fan Company 5/1/1 Programmable...
My air conditioner will only turn on for a moment then shuts off
it sounds like you have a thermostat problem you can either take the thermostat of the wall and check the wires to see if they are all connected, or you can replace you t-stat. you also could have a bad contactor. without having technical knowledge it will be hard to fix, your best bet is to call an A/c shop and have a tech look at it.. it shouldn't be too pricey. 60 for the tech to diagnose it and if its the contactor it shouldnt be much over 100 dollars.
Jun 05, 2009 | Intertherm P3RA-048K Air Conditioner
Relay board for thermostat/condenser fan/n compressor need to mak
I have a copy of the wiring diagram for this unit. If you would list your email address, I will email the diagram for you. This will give you everything you will need to insure that the unit is wired correctly.
Mar 20, 2009 | Intertherm P3RA-036K Air Conditioner
I need wiring diagram and color codes for a hunter thermostat
Basic diagram would be as follows
Red wire to R
White wire to W
Green wire to G
blue or yellow Y
Jan 25, 2009 | Heating & Cooling
Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Jun 17, 2008 | Coleman Mach III Air Conditioner
How to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Feb 07, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Jan 12, 2008 | Hunter Fan Company 5/1/1 Programmable...
Intertherm P3RA-048K Air Conditioner Logo
308 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
