Question about iPhone Apps
Sync kobo cannot sync kobo glo
My Kobo Aura is not recharging. The charging unit seems "dead". Can the charger be replaced?
it can
Kobo Aura / Aura HD compatible Advanced Rapid Wall AC Charger ...
https://www.amazon.ca/Kobo-compatible-Advanced-Rapid-Charger/.../B00GNB08JS
Gomadic Powerful High Wattage wall charger for home or travel use. Customized circuit design is based on the latest in power regulation and is tailored to the ...
Kobo Aura One Charger, BoxWave® [Wall Charger Direct] Wall Plug ...
https://www.amazon.ca/Kobo-Charger-BoxWave®-Direct-Touch/dp/B01MA3NLF8 Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc 7 10 HD; Kobo Touch Glo Mini Aura Hd Ebook Tablet.... ... HQRP Micro USB Charger / AC Adapter for Kobo Arc / Arc 7 / Arc 7HD / Arc 10HD / Mini / Glo / Touch / Aura / Aura HD / Vox.... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid ...
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones ...
https://www.amazon.ca/Kobo-eReader-Glo-USB-Cable/dp/B00AXZVE48 Rating: 4.7 - ‎11 reviews
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones & Accessories. ... Cable for Kobo eReader Kobo Mini, Kobo Touch, Kobo Aura & Aura HD... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc ...
Chargers & Cables - Electronics: 146 products available ' chapters ...
https://www.chapters.indigo.ca/en-ca/electronics/chargers-cables/500151-cat.html Results 1 - 24 of 146 - Shop Online at Chapters.Indigo.ca for a wide selection of chargers & cables products, 146 items available. Enjoy free shipping on orders ...
kobo aura charger Google Search
Sep 24, 2017 | Tablets & eReaders
How do I transfer new books from computer to ereader,I bought 2 new books they show on e reader in a little box but cannot be accessed
Have you tried a usb from your computer and connect it to your ereader , you should be able to transfer from one to the other that way otherwise how else would you transfer without a usb device?
Dec 20, 2014 | KOBO, INC Kobo Glo
I downloaded a book onto my kobo glo and it just says pending? What does this mean?
You likely have to authorize it again as it thinks you have downloaded it as another non-paying subscriber. Contact the outfit you ordered it from.
Sep 21, 2014 | KOBO, INC Kobo Glo
Problem with internet connection says when I connect my KOBO to computer and cannot sync any books. Kobo charged and can't access KOBO on computer
It could be several things. But you may need to delete Kobo and reload the app. I have had to do this on some of my programs. Your books are on the net, so they won't be lost.
Aug 02, 2014 | KOBO, INC Kobo Glo
Sync kobo
You may need to delete KOBO and re-install the app. Your books will be saved because they are online.
Kobo Glo ereader
try to reset it..... how to reset device would be written in you users manual
Jan 14, 2014 | KOBO, INC Kobo Glo
After factory reset of my kobo glo, I couldn't get back my books that I ?
First make sure your books are really (still) in your account. Log into Kobobooks.com and check your library. Here's a direct link to the library page: Sign in to Kobo with
If you don't see your books there, you didn't buy them under that user account, or they're been removed from your account. Call Kobo support in either case.
If the books are there, make sure your Kobo eReader is also logged in using the same account. To do that,
1 - Open the menu
2 - Tap Settings
3 - Tap Account
Under 'Signed in as', you should see your user account. If not, tap in Sign in and log in. After that you can sync your library with your Kobobooks.com account from the menu again.
Dec 18, 2013 | Kobo Glo eReader Silver - N613-KBO-S
I have a Kobo Glo. I use the Adobe digital system to download all my books primarily from the public library . I've had no problems (got this in June) . Now when I tap the sync tab I get an error message....
are you sure you have not exceeded your memory capability?If it has it will bump a book every time you add a new one..it has to to load the new one each time ..may require a larger micro memory card...OR you could have dropped a driver from the adobe file and checking settings. you may have to do updates on it..Or you have a problem with syncing ..again that may be just an update to KOBO default settings.Hope these can help .Kobo.com support can help as a last resort ..GOD BLESS
Jul 28, 2017 | Kobo eReader
iPhone Apps Logo
44 people viewed this question
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
