Question about Dishwashers
HOTPOINT LFT114UK not filling
Select the programme, machine pumps then starts to fill and after a minute it pumps the water out and the first three lights flash
  • 1,511 Answers
Circuit board may have a short and fails to complete the administration of commands to the solenoids. Many times the timer section is effected by power surge and repeated use. Factory service is the only way to repair this , unless you are a technician.
Posted on Apr 15, 2014
  • steve jenner
    steve jenner Apr 15, 2014
    thanks, suspisions confirmed.
  • Dayton Computer
    Dayton Computer Apr 15, 2014
    Hope you get it corrected.
Meiko dishwasher. Do I have an eeprom problem?
sounds like it could be a defective cylinoid switch...this will not allow water to flow properly through the machine....this is located at the water connection....try replacing and reconnect water...good luck
May 19, 2014 | Meiko Dishwashers
How do i program a replacement pc board controller
For module configuration information on Hotpoint WMA range of machines go to www.selfix-uk.co.uk and click on the ERROR CODE link.
Feb 29, 2012 | Hotpoint WMA40 Front Load Washer
After commencing a programme my Hotpoint BF71 dishwasher takes in water but overfills, filling the whole of the tub nearly to door level. The waste pump starts for a short burst and then more water comes...
Check for a float switch that senses the water level. It may have two level sense of filled and overfill the latter would trigger the waste pump to avoid a flood. If the filled switch has failed, that could cause the problem. The waste pump MAY also be triggered on the basis of the filling taking too much time before the filled switch actuates... if it has failed, the time would be exceeded.
Dec 13, 2010 | Hotpoint 24 in. BF72 Built-in Dishwasher
Only takes on cold water will not take on hot when you disconnect pipe hot water runs through so supply is ok
If it is a hot and cold fill washer with 2 seperate inlet hoses, and no hot is entering, then either the hot inlet valve is faulty, or the valve is not getting an electric feed to it.
Make sure that the programme you select is ahot prog, as many of the programmes are3 cold fill only.
Mar 28, 2010 | Hotpoint WMA58 Front Load Washer
I have a Hotpoint BWd129 washer/dryer. When I
I have a similar Hotpoint model to this, that does something very similar now and again, usually when trying to set a delayed start.
The only way I have found to "fix" it is to turn the machine off for at least 5 minutes, and then try again.
Hope this helps.
Jan 13, 2010 | Zanussi WJD1257W Front Load Washer
Hi I have model No WF 740 1400 spin! However programme L is filling up with water, appears to be washing as normal until it reaches final 7 minutes, then machine becomes laboured and will not spin! the...
it appears that the pump is not removing the water that is spun out  if there is a belt on the pump then it may have fallen off or need replacing   if it is intact then the pump either failed or there is a blockage in the line
Nov 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wd420 not pumping
Hi,I have just been on a service call to the same model,the pump windings had shorted turns and after replacing the pump i have found that it has also damaged the module(pcb assembley) not good considering the module is 120 uk sterling!!
Feb 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT WD71 ERROR E 30
Hello john walker24
Welcome
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
Any idea what the problem is?
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Huuum,
Please remember to leave a rating!
Thank You.
Waiting for your response!
Oct 01, 2008 | Hotpoint Ultima WD72 Front Load...
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
Owen Barnes
