Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Normal + rinse light flashing on dishwasher
Normal + rinse light flashing. I have tried all the resets but nothing works. I want to replace the part but don't know whether it is the Dishwasher control or the electronic control?
3 Suggested Answers
  • 77 Answers
SOURCE: Won't run - normal light flashes
You may try removing power to D/W for a minute and reconecting. likely cause though is keypad (console). If a light above a pad stays on the pad is likely closed all the time. Normal is probably cycle most often used. you can test the keypad by removing power to D/W and accessing the control panel. remove conncter P-1 and using an ohmeter test resistance between 13 and 4 on the connecter coming from keypad. yes without very small clips or 4 steady hands it is a little tricky. in the field we use a breakout board. if you get any reading when not pushed pad is bad. you may find a manual inside the kickplate which explains the keypad sequence. it may be control but more likely keypad, even if test is inconclusive.
Posted on Jun 07, 2008
When I had this problem, it turned out to be the heating element.
Posted on Aug 16, 2008
it sounds like something has came loose. you have to take the control panel apart and you should find a grey flat plastic cabel about 2 1/2 to 3 inches wide.hook it back up and maybe use some electrical tape to keep it in place and that should fix it.
Apr 15, 2014 | Whirlpool 24 in. DU1100XTPS Built-in...
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
Normal light blinks
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Daniel
Apr 17, 2011 | Whirlpool Dishwashers
"Normal" light flashes
You need a new control bd. #W10084141. If the diagnostic mode will not work then the board will have to be replaced.
Mar 06, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
Quiet guard 3 dishwaher
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Sep 23, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
16 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
