Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Cannot exit the local option on my Toshiba TV
I have a URC 22B remote control and I am trying to exit the local option appearing on the screen but can't find the right button on the remote
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
  • 1694 Answers
SOURCE: Toshiba 36inch color tv demo troubleshooting
Demo is activated / de-activated by holding a combination of
two buttons on the tv front for at least four seconds. Try menu &
power or vol up & chan up...........T.
Please rate this solution.......
Posted on Nov 12, 2007
jerryg50
  • 1673 Answers
SOURCE: Toshiba TV - 29 inch - model 2990 XEL
This may be a fault with the firmware (internal software for the uPC), or it may be a failure in the circuit area or chip that generates the fonts and characters for the menu display.
You will have to send the set for factory level service if this is the case. If you give the set to an independent service center, they may have to send the set out on your behalf.
I would be careful to not invest too much money in to servicing a TV of this generation.
Jerry G.
Posted on Jul 12, 2008
SOURCE: My remote will not work
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Posted on Mar 19, 2009
  • 26 Answers
SOURCE: I dont have the remote for my television and was
get a universal remote from best buy, or walmart and program it to your TV.
Posted on Jul 13, 2009
How can I operate my VCR using a URC 22B remote?
The URC indicates the remote is universal, which means you can use its CODE SEARCH (or equivalent) feature to find something that will manage some or all functions of your LG VCR. If a search through all codes stored in your remote fails, you may have to try a different URC. All universal remotes do not store all possible codes.
Feb 04, 2016 | LG Televison & Video
NEED TO ADD CODE TO URC REMOTE
Try these instructions and see if they work for your genie remote.
First, have your Genie Mini receiver connected and powered on. Next, grab your RC71 remote and simultaneously hold the "MUTE" + "ENTER" buttons until you see a box appear on your TV screen that says "Applying IR/RF Setup. Please Wait" (this appears after about 5 seconds of holding those buttons). Once complete another dialog box will appear and read, "Your remote is now setup for RF." Click "SELECT" to exit that screen. Next, click the "MENU" button, scroll down to "Settings & Help", then click on "Settings", scroll down to and click on "Remote Control", then click "Program Remote". Next you will have two options, either "Program TV" or "Program Audio Device". Click "Program TV", this takes you to a screen where you need to select what BRAND your TV is. After you have selected your TV brand you will have to select the TV Model ( I recommend looking at the sticker on the back of your TV for the accurate Model number or using your current TV remote to find the model number from the menu screen on your TV for fastest and best results). Once the correct model number is selected, AIM your RC71 remote at the TV and it will AUTOMATICALLY program!
Jan 29, 2014 | One For All URC-9910 LCD Remote Control
Universal remote control code for a **** Smith LCD tv model GE6832
032,031,037. Try these codes. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Nov 08, 2013 | Televison & Video
Umc tv remote code
What is the brand name of device do you want setup codes? If you wish to get more details, check this link. http://electrohelponline.blogspot.com/ Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there
May 17, 2013 | Televison & Video
I have urc-22b remote control but i dont have the code for my tv which is techinka
Try this:
Manually turn on your TV.
Then push and hold the code search button until the light stays lighted. Release the button.
Push and release the device button you want to set (i.e. TV)
Now push and release the ON/OFF button until your device turns off. When your device turns off, stop and push and release the enter button to store the code.
Warning: You may push and release the ON/ OFF button for almost 200 times.
Good luck.
Aug 11, 2010 | One For All URC-3021 Remote Control
I need code for my nse urc22b-10 universal remote control
i have a panasonic tv i want code for urc-22b-10 remote controler
Oct 07, 2009 | Teac RC-L2 LCD Touchscreen Remote Control
URC 22B UNIVERSAL REMOTE CONTROLLER CODE
Philips TV, URC22B remote. Need help with codes.
Mar 15, 2009 | Zenith ZN110 Remote Control
Tryin to link universel remote control to sony trintron tv
press and hold set key  press tv then enter one of the following codes as one of them will work for your tv 028   119   126 127   128   129 130   182   199 228   260   705
Dec 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
DEMONSTRATION ON SCREEN
Enter Menu2.
Press Recall. Exit or Power.
http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2004/32a33_32a43_36a43_rev219_ownman.pdf
Feb 17, 2008 | One For All URC-3605 Remote Control
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
79 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
