Gx 460 no sound coming from speakers And no beeps when I push buttons What's the problem
    Sergeant:
  • 240 Answers
Need more information; who is the manufacturer? Is the computer powering up or totally dead? Anything at all on the monitor? Is your problem only with the sound, or other things as well? This is a problem that this forum is not set up to handle, it is just too difficult for back n' forth conversations. I hang out here: www.suggest-a-fix.com
Post in on the Hardware & Multimedia section and you will get help a lot easier. This is a free, computer help forum, by the way.
Posted on Apr 16, 2014
Our GX 460 is now showing the check engine light with the anti skid light on s well. Also, the light flashing 4 low is on and car will not accelerate
You MUST READ the error codes to learn which detected fault is causing the 'limp home' mode. Try PepBoys or Auto Zone etc free Scan to read the codes. May require DEALER diagnostic computer to reset/clear the error code(s) and/or repairs. Good Luck, it may be trivial loose connector or may be mega-buck disaster
Sep 13, 2014 | 2010 Lexus GX 460
The check engine light is permanently on and 4LO has been blinking on my 2011 Lexus 460
This is a warranty issue see the dealer, do not repair it yourself or touch the engine.
May 30, 2012 | 2011 Lexus GX 460
I need oxygen sensor 1 and 2 and Catalyst Bank 1 for my Lexus Jtjbm7fx95002924
Rock Auto .Com---better prices than local auto parts
There should not be an issue with an O2 Sensor
on a 2011 vehicle
No vehicle OBD2 Code, tells you anything needs to be
replaced,study obd 2 systems
The codes are used to diagnose a fault in a system
May 29, 2012 | 2011 Lexus GX 460
Hi ! I've got a Winfast 760M02-GX-6ls
First, ensure that the leads from the motherboard to the internal speaker are connected.
Second, try "flipping" the connector, at one end, to make sure that you got the "positive" and "negative" leads correctly connected.
Third, put a multimeter onto the leads on the motherboard, and then turn the computer on,
and watch to see if the multimeter records any voltage where the "beep" should be.
Fourth, try replacing the AMD CPU, if only temporarily.
Aug 02, 2011 | Computers & Internet
I have a Technics Stereo Receiver SA-GX 500. There is very little sound coming out of all the speakers (A and B) as well as the headphone jack. I have made sure that the speaker button is depressed (A, B...
All sources or just one? Make sure the Tape Monitor isn't engaged unless you're using an external tape deck or processor. A turntable will only work on the PHONO input.
Aug 08, 2010 | Technics SUV500 2-Channel Amplifier
I have a Viewsonic VG2021m.. I think the speaker (s) is not working. There is no sound coming from my monitor.
your monitor have 4 buttons in the right down. the first is for turn on or off the speakers ;)
Apr 28, 2010 | ViewSonic VG2021m LCD Monitor
Want to disable beeping sound from keypad
Remove the 4 screws inside the door, remove the cover and find the speaker then twist it gently with a pair of pliers until it pops off. The speaker is black, round and has a hole in the center. To be sure you have found the speaker put your finger over the hole and push a button on the keypad, if the beep sounds different than normal you have found it.
Apr 06, 2010 | Locks & Locksmithing
STUCK ON THE LEFT HAND SIDE WOULD NOT RESET ITSELF WOULD HAS THE BEEPING SOUND LIKE AN ALARM WOULD NOT MOVE WHERE IT IS AT....
what you need to do is push the black lever back forword it comes back has you pull the ink cartrage out that will make it reset good luck
Sep 28, 2009 | Brother GX-6750 Typewriter
Toshiba 2010H
When you press any button the speaker will make a quick beep. Is this what you are asking about or are you asking about the DTMF tones when you press a number button 1-9,0,*,#
Sep 21, 2007 | Toshiba DKT-2010H Corded Phone
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
