Question about WYSE WT-3200LE (WT3200LE) Network Terminal
Cannot reset WT3200LE to factory defaults
After making change to the terminal configuration I rebooted and now get error input not supported. Please help first time user.
3 Suggested Answers
  • 25 Answers
SOURCE: Hard Reset
Youch, thats a pickle!!
Basically, because the terminal is in loopback mode when in the OS, you would need to find an up to date .i2d file, and for the S10, then try and re-image it with Wyse Simple Imager. This will use PXE and DHCP option tags to grab the device, and push an image to it.
Make sure PXE is first in the boot order in the BIOS, people often forget this!!
All the software you need (apart from the i2d file) is available from the Wyse website. When it comes to the i2d file, you will need to contact Wyse directly to get hold of this.
http://www.wyse.com/serviceandsupport/support/downloads.asp
Posted on Dec 18, 2008
SOURCE: connection reset by peer
Please upgrade to latest Citrix WTOS build. Try build 6.4.0_24. it has fixed the issue
Posted on Dec 15, 2009
How to reset password for motorola surfboard cable modem sb6141
There is no password on the SB6141.
There are no user configurable options. Any configuration is changed through communication with the CMTS.
When you access the modem (192.168.100.1) all you can do is monitor the signal quality and certain log entries.
NOTE: the "configuration" page allows you to reset the factory defaults and to restart the modem. IF you reset factory defaults this note applies:
Resetting the cable modem to its factory default configuration will remove all stored parameters learned by the cable modem during prior initializations. The process to get back online from a factory default condition could take from 5 to 30 minutes. Please reference the cable modem User Guide for details on the power up sequence.
Aug 24, 2014 | Motorola Computers & Internet
My Cisco IP Phone 7945G keeps rebooting after I did a factory reset. Is there a way to fix this?
According to Cisco, when initiating a factory reset procedure certain information from the IP phone is erased while other information is reset to the factory default value, as shown in the list below:
Information Erased:
  • CTL File (Certificate Trust List)
  • LSC File (Locally Significant Certificate)
  • IP Phone Call History (Calls Received, Placed, Missed etc)
  • Phone application
Information Reset to Default:
  • User configuration settings (ring tone, screen brightness, sound levels etc)
  • Network configuration settings
t is highly advisable to follow the firmware upgrade procedure in a non-working environment to ensure other phones are not affected (in case of an accidental reboot), and to avoid the freshly factory reset ip phones obtaining the working environment's settings.
Please use the link below and follow the instruction http://www.firewall.cx/downloads/cisco-tools-a-applications/cisco-ip-phone-a-ata-firmware-downloads.html
Aug 28, 2012 | Cisco 7945G IP Phone
How to reset netgear wgr614 to factory default
You can reset your Netgear router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings. For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Get instant Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router problem.
Jul 26, 2012 | NetGear WGR614 Wireless Router
I for got my wifi password that i set so now i cant get on the internet any more? PLEASE HELP
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds).
2. Release the Default Reset button and wait for the router to reboot.
If the wireless router fails to restart or the power light continues to blink or turns solid amber,
the unit may be defective. If the error persists, you might have a hardware problem and should
contact technical support.
the manual can be found here:
http://kbserver.netgear.com/pdf/wpn824_ref_manual.pdf
Please rate my solution.
Jul 04, 2011 | NetGear RangeMax WPN824 Router
How do you reset a password?
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
Apr 03, 2010 | NetGear DG834G Router
I dont know the pass code...?
the simplest way is by restoring the default configuration and then reconfigure the passcode.
You can erase the
current configuration and restore factory defaults in two ways:
• Use the Erase function of the router (see “Erasing the Configuration” on page 6-7).
• Use the Default Reset button on the rear panel of the router. Use this method for cases when
the administration password or IP address is not known.
Dec 25, 2009 | NetGear WGR614 Wireless Router
HOW COULD I REBOOT MY PC LIKE NEW
If I got you right, you want to restore your computer to the default factory configuration.
Please go to the following page:
http://support.dell.com/support/edocs/systems/ins1521/en/om_en/html/trouble.htm#wp1063103
When you are there, scroll down a little bit to the section:
Restoring the Computer to the Default Factory Configuration"
Follow the instructions to restore your system to the default factory configuration.
Dec 16, 2009 | Dell Inspiron 1521 Notebook
Wireless light is not on
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot. If the wireless router fails to restart or the power light continues to blink or turns solid amber, the unit may be defective. If the error persists, you might have a hardware problem and should contact technical support.
Nov 27, 2009 | NetGear RangeMax WPN824 Router
Wyse 1200LE - error - out of frequency
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset. If so, just hold down the G key when the terminal is booting, and it will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration.
May 28, 2009 | WYSE Winterm S30 Network Terminal
I have some problem with my monitor frequency and wyse terminal frequency.Its overrange, i can't see anything when i power it up.Can smbd tell me how to reset factory default with power on.
Feb 22, 2009 | WYSE WINTERM 1200LE Network Terminal
Computers & Internet Logo
Top WYSE Computers & Internet Experts
Nicholas Bannister
Tim Hunt
Tim Hunt
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
