Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water is leaking from refrigerator. Is there any
Water is leaking from refrigerator. Is there any place I can get a manual? Thanks.
  • 35 Answers
CALL WPL
Posted on Jun 18, 2009
Water accumulating in bottom of refrig.
What is your model number? Every different model leaks differently but the same reason (defrost drain frozen shut) causes water to appear in different places in different models. Click here=> Leaking Refrigerators
I'm here should you have question, Thanks, Sea Breeze
Oct 11, 2015 | Refrigerators
Water dispenser leaks
Refrigerator Water Dispenser Leaks?
Refrigerator Water Dispenser Leaks show that the refrigerator's water system has a problem. To fix this problem, open the filter compartment and pull out the filter and push it back in so that it is secure in place. Push compartment cover until it clicks.
try to check this video.
May 13, 2014 | KitchenAid Superba Architect KSCS25INSS...
Leaking viking fridge
We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Leaking Refrigerators Just What may Be Happening
Jun 18, 2012 | Viking Refrigerators
Water draining into refrigerator crisper.
Your defrost drain is blocked and now every time your refrigerator goes into defrost the condensate remains inside your refrigerator. Click Here=> Leaking Refrigerators Just What may Be Happening and read that page and then click here=> Leaking Refrigerators You refrigerator appears to be almost the same as the photos on the Leaking Refrigeratores Link. Read over all of the different ways leaks happen and if this solution is helpful please rate the solution because I need all the rate's I can get. If you have questions please ask, Thanks, Sea Breeze
ET1MHKXM Parts Manual
ET1MHKXM User Manual
Get Adobe Acrobat Reader
Jun 29, 2011 | Whirlpool ET1MHKXM Top Freezer...
My whirlpool gold gr2shkxks01 has water collecting in the bottom of the crispers and moisture on the shelves, what is the problem; it is driving me crazy
Your defrost drain is blocked and now everytime your refrigerator goes into defrost the condensate remains inside your refrigerator. Click Here=> Leaking Refrigerators Just What may Be Happening and read that page and then click here=> Leaking Refrigerators You refrigerator appears to be almost the same as the photos on the Leaking Refrigeratores Link. Read over all of the different ways leaks happenn and if this solution is helpful please rate the solution because I need all the rate's I can get. If you have questions please ask, Thanks, Sea Breeze
GR2SHKXKS01 Owners Manual
GR2SHKXKS01 Parts Manual
Jun 29, 2011 | Whirlpool Gold GR2FHMXPB 21.6 Cu. Ft....
Water does not drain and freezes under freezer draw
I am sending a couple links for the LG manuals but that sounds to me that water is either overflowing into freezer compartment from the fresh food compartment or when the freezer goes into defrost the drain that carries the water out to a condensate pan below refrigerator (Location #105A) has either ice or sludge caught in the drain. Here is the=> LRFD22850 Exploded View then scroll to page 44 where you will see the location number 319A That will be the condensate/drip collection tray where the water from defrost should be going. If the drain location # 105A is the drain assembly, pipe Z coming from under your freezer drawers. Where you say you see the water pooling and freezing. And the Service manual Click Here=> LRFD22850 Service Manual I will try to make this simple but I must try to explain with photos and notes with other links=> Leaking Refrigerators Just What May Be Happening and here=> Leaking Refrigerators! This may take some detective work because as you see any place there is water there may be water flowing down to the area below freezer drawers so look for any water that may be coming even from the water filter area inside fresh food compartment.Even a slight lean will cause the water to pool up and freeze there and close the drain slowly. If you should need parts scroll to page 51 in your Service Manual and on left is the photo location and on right is the part number under the model LRFD22850 then enter the part numbers into search feature here=>
Repair Clinic or Sears Parts Direct Here is the new=> Adobe Reader X
I also will be here to answer any questions you may have, Thanks, Sea Breeze
Jun 05, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
I need a replacement water line for my LG LSC26905TT. The line is cracked and when I try to dispense water the line leaks.Where can I look for this product? Thanks for any info. Alan
If the water is leaking from the freezer door hinge the door would have to be replaced as the waterline in the door is foamed in place.
If the leak is from the back where the plastic lines are they are replaceable.
Contact LG @ 1 800 243-0000 and give the exact location of the bad waterline since there a couple on the unit.
Jan 19, 2010 | LG LSC26905TT Side by Side Refrigerator
Refrigerator leaking water
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Sep 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaking from bottom of refrigerator
hello there,
well,if you can buy to replace the evaporator tray in order to solve the leak,you can buy this from refrigeration supply near your place,or have to fix or repair if can do so,have a glue gun and try to weld the crack in order to hold the water defrosted from evaporator and leak will not appear.you can buy glue gun from school supply or hardware near your location or in mall.have a nice day,don't forget to rate me.thank's alot
May 08, 2009 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
132 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
