Question about GE 30 in. JGP326 Gas Cooktop
Access cooktop underside - GE 30 in. JGP326 Gas Cooktop
  • 1,511 Answers
Just lift it up. At the seems on each corner, pull up and it will lift.
Posted on Apr 15, 2014
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
How do I remove the spark igniter when replacing a burner bowl on GE JGP 636 gas cooktop
The spark ignitor is attached to the burner bowl by a retaining clip under the bowl. Simply remove the two screws on the top of the bowl, then you can slide the clip off from the underside
Jan 23, 2010 | GE 30 in. JGP326 Gas Cooktop
The Grill side on my electric cooktop doesnt seem heat up enough
I had the same problem with the 45" Jenn Air downdraft cook top. The installation of the ductwork from the stove to the outside of the house was not properly installed. The stove is appr 18' from an outside wall and the flow of air was hampered by
too great a bend in the ductwork at the point below the stove on the underside of the house and the pipe going to the outside wall. I believe that was corrected with more curve in the vent work, making for a smoother flow of air. Make sense?
Jan 07, 2010 | Jenn-Air JED8230 Electric Cooktop
I have a Jenn Air gas cooktop, only about 2 years
If the burner just clicks and won't stare try this (a local tech showed me) Scrape the underside of the burner cap (the removable black disk in the middle of the burner) with a key or knife and watch it work! But be ready to do it again and again. There's a glossy finish left by the factory he said.
Jan 03, 2010 | Jenn-Air Cooktops
I wasn't supplied with a manual. Need to know amperage
should be sticker on underside of unit to give you this info
Aug 08, 2009 | General Electric 30 in. Profile PP950...
Looking for the rubber feet that fit on the
You can get these feet at www.repairclinic.com
May 11, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Right front burner on high all the time.
Yes, the entire unit must be lifted out - it is probably secured with screws underneath. Then you can remove the screws on the underside of the glass to access the switch. Hope this helps!
Dec 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at sears.com.
Apr 07, 2008 | Cooktops
Re-ignition when cabinet below doors open/close
Seal all holes on the underside of cooktop. This is called the burner box. Seal all openings with aluminum tape. This should stop the back draft effect.
Mar 24, 2008 | Jenn-Air JGC8536 Gas Cooktop
GE 30 in. JGP326 Gas Cooktop Logo
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
