Question about Nokia 3110 Cellular Phone
Push to talk - Nokia 3110 Cellular Phone
  • 1,511 Answers
Push to talk means you push the button by depressing it when you want to change the process from caller in to caller out. This changes the circuit instantly from Reception to Transmission.
Posted on Apr 15, 2014
Can you stop motorola radio from beeping each time talk button is pushed
Nope...That beep lets you know that you can commence talking. If you start talking before you hear the beep, whoever you're talking to will not hear everything you say.
Sep 12, 2016 | Motorola Radio Communications
Unable to switch push to talk
14. Push to talk Push to talk (PTT) is a two-way radio service available over a GPRS cellular network (network service). You can use PTT to have a conversation with one person or with a group of people (channel) having compatible phones. While you are connected to the PTT service, you can use the other functions of the phone. To check availability, costs, additional features and to subscribe to the service, contact your service provider. Roaming services may be more limited than for normal calls. This feature may not be available, depending on your phone. For more information about signing up for the PTT services and the usage, contact your service provider. To connect to the PTT service, select Menu > Push to talk > Switch PTT on. LOOKS LIKE YOU HAVE TO SUBSCRIBE TO USE IT! hope this helps.
Oct 08, 2012 | Nokia 6300 Cell Phone
Button for push to talk?
there is no button for push o talk just activate the mms/gprs and then used to another cellphone also have a push to talk feature.i think 10 meters away to connect the calling.
Dec 22, 2009 | Nokia 5300 Grey Cellular Phone
Who to use of push to talk
push to talk is good to have
Jul 19, 2009 | Nokia 6020 Cellular Phone
Hang up
Button on side is not for answering calls.
PTT or Push To Talk allows you to use your mobile like a walkie talkie. It is dependant on your network operator running the service.
Quote from Pocket lint:
To use the function you must first create a group or individual in your phone menu and send an SMS invitation to those you wish to join. Once your contacts are set up, your phone shows which members have their handsets switched on with push-to-talk enabled, in the same way that instant messaging works online. By pushing a single button on the handset, you are connected with one person or with your group. There is no need to dial numbers, nor do the recipients need to answer calls. You simply push a button and talk. As with a walkie-talkie, anyone in the group hears you almost instantaneously. The talking is one way with only one person able to speak at a time. Unlike walkie-talkies, which are infuriatingly dependent on distance, push-to-talk has no such limitations.
You should be able to disable PTT in the Nokia menu, which is best if your network doesn't support it. Plus you won't keep cutting off calls.
Apr 23, 2009 | Cell Phones
How to setting ''push to talk''
the push to talk depends on the network settings contact ur network.
Mar 19, 2009 | Nokia 5300 Grey Cellular Phone
Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
Dec 16, 2008 | Motorola Walkie Talkie 2-Way Radio
Push to talk..
you had get the incomplete or wrong PTT or GPRS settings.
as u know, Push to Talk uses GPRS so if the GPRS settings are wrong PTT cant be accesed. I had the same problem also
Dec 10, 2007 | Nokia 6020 Cellular Phone
Earbuds
If you are using vox (voice activated transmit) go into the menu and make sure you don't have the VOX setting too high. You should be able to put the headset on... hit the "push to talk" button on the radio and transmit you audio. Turn the other radio on and make sure the radio is "keying" (tx with no auio) then make sure there is audio. If you don't have audio but the radio is transmitting.. you might have the wrong type of plug on your headset for the audio..... there are 2 plugs... 1 for transmit audio....1 for recieve audio. It could be the wrong type of plug for the jack in the radio. Regardless.. the way the headset works is either you push the "push to talk button" onj the radio OR you use the VOX function... with the vox function you just have to talk into the mic to transmit. This is what your headset is designed for. You will have to go into the menu and set up the radio for VOX. If you still have problems follow my directions at the top of this page ( check mic jack and stuff) I think you just have to set the radio up for VOX operation and set the VOX setting. You should be able to push the push to talk button and talk through the mic on the headset. If you don't get any audio that way there is a problem and you should check the jack and plug on the headset.
Aug 25, 2007 | Motorola Talkabout T5720 (7 Channels)...
Nokia 3110 Cellular Phone Logo
23 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
