Question about HP Computers & Internet
How to turn on the biometric device - HP Computers & Internet
  • HP Master
  • 1,511 Answers
Go to the SERVICES and select the option in the Properties area that allows you to Turn On The Biometrics. It may be restricted now and your current selection in the Properties may be set to the OFF Position.
Posted on Apr 15, 2014
Bizhub c224
In order to enable this function, you will need AU-101 / AU-102 Biometric Finger Vein Authentication Device. These biometric finger vein readers connect directly to the MFP and work in conjunction with the machine's internal authentication capabilities, or integrate with Konica Minolta's PageScope Enterprise Suite.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 19, 2014 | Konica Minolta Bizhub C224 Color Copier /...
Biometric finger print verification problem in IE8 32Bit
go to control panel
open java
you see java configuration
go to security tab
select use java in brousers
and scrool down secruty bar to medium or low
restart computer and check
Feb 08, 2014 | SecuGen Hamster Plus Fingerprint Scanner
Unable to obtain authentication input/output error has occurred. Error while loading applet Module is not registered.
Check to see if more than 1 biometric scanner is enabled @ device manager>Disabled all leaving only 1 supported finger print scanner enabled.
This error is most common if you have on-board or integrated biometric Reader...Try this 1st;still got answers if this doesn't work but it's been proved as remedy for this particular error :) Thanks
The Rule is:Help others without charge :)
Jan 10, 2011 | DigitalPersona UareU 4500 Fingerprint...
I just purchased the device and trying to load it through www.jamb.org.ng/Unifiedtme/ registration platform but the response received is authentication error i.e. I can't thumbprint.
You will get this kind of error "authentication error "
1. This kind of problem happens when you re-formatted your computer
2. You just install your scanner this year for the first time.
3. You did not have biometric license key installed on your computer, this license makes your scanner authenticated over the internet when you are visiting jamb website, if you are in Nigeria. It also comes with Jamb Biometrics Capture Software, .Net Framework, Java Framework and other software that will make your experience very simple after installing.
4. If, you have the license, then you did not supply the 16 digit security code for the scanner.
The way you out, you need BIOMETRIC LICENSE, if you are operating JAMB BUSINESS.
Hope this help you, if you need more clarification you can email me on biometricmasters2000-jamb at yahoo.com or phone me on 08132829820
Dec 29, 2010 | DigitalPersona UareU 4500 Fingerprint...
I am using windows 7 ultimate on acer 5738 and system reports that Windows did not find any biometric device on your system. In device manager, biometric device Authentec shows and reports that device is...
Visit the support section of Acer's website. There you will find if they have Windows 7 drivers for this unit.
If they do not have Windows 7 drivers there may not be any for that unit.
http://www.mylive-tech.com
Jan 03, 2010 | Acer Aspire 5720-6661 Notebook PC
Couldnt Find fingerprint equipment
Let me elaborate on what the other two were telling you. First, your fingerprint reader is a scanner, if it is showing up as a scanner then you have the device installed. Second it may not have the right driver installed so that the biometric software doesn't realize it's the right device.
First you need to install the driver from the backup you made for the fingerprint scanner. If it doen't work or is not on the backup then you neew to go to www.acer.com pick your region, then get into the driver downloads for your model. You will need the full model # ex AS5730-54857 off the bottom of the laptop to get into the downloads. Once you're in download the newest update for the finger print scanner.
Once you have that installed it should show up properly in the device manager and the biometric software should recognize it. It is always important to install the drivers before the software for these devices as otherwise they will not work. The software installer needs to see the proper device at the time it installs, so if the biometric software is currently installed, remove it then proceed with installing/updating the driver.
Chris
May 26, 2009 | Acer Aspire 6930-6455 Notebook PC
Problem resetting Biometric fingerprint scanner Sony Vaio VGN-SZ360P
Yes, you need to try to locate the program folder and attempt to delete it. or you can use the KillBox program that will force delete the program. If you would like that send me a email jcamphelp@hotmail.com and I'll send that to you....
Oct 27, 2008 | Computers & Internet
SentrySafe DA3930 Biometric Fingerprint Safe Item Number 681814 will not recognize my finger print!!!! I have been trying to get into it on and off for 3 months. Is there a reset code???
contact sentry
biometric scanners DO NOT WORK
prove your ownership
and they may assist you
and
Sep 14, 2008 | Sentry Fireproof Safe
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
