Question about Mackie cfx20 mkII compact mixer
EQ slider control
125hz slider physically broken. Would like to purchase a replacement slider or a complete EQ slider assembly.
  • Ismael Gonzalez
    Ismael Gonzalez Apr 15, 2014
    The part you are looking is the Mackie 130-075-00. This is the fader that you need. Contact the people of FullCompass.com for the part. Hope this solve your problem. ICPDP
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Left hand slider pitch control needs replaced due to fluid spill.How can I acquire a replacement part in New Zealand.I was playing at a function and a local drunk spilled alcohol on my controller.Im not...
DO NOT USE CONTACT CLEANER !!!!!! It removes the lube.... If you can find it there, use CRC226 in the faders. You MIGHT be able to restore the fader with it. With the spout put a bit right in the center of the slot and work it. Here I get it in the electrical dept of Home Depot... not sure what they have in New Zeeland. Replacing the fader takes a lot of labor as the panel has to be completely disassembled. You can probably order CRC226 online if you can't find it in a store there. Here it is about $2.75 for a can.
Sep 20, 2011 | Behringer Bcd3000 B-control Dj Mixer...
Some of my eq sliders are broke off and i was wondering if i could get just a nother circut from behringer if it is fixable Terry
Depending on how its built and if your good with circuits i couldnt see why not. If its under warranty though make em give you a new one
May 09, 2011 | Behringer PMP2000 800 Watt 10 Channel...
HI, I just need the value/taper of the 30mm slide potentiometer used in the equalizer of the Behringer K1800XF.
The sliders in almost all of the EQ's in Behringer are linear taper (B). The values are usually 50K. Fo replacement make sure you get matching mounting spacing. Almost all Behringer pots are made by ALPS.
Note that the rotary volume controls are G (graphic) taper, often 50K and are hard to get. trying to get these from the Behringer parts distributor was futile... gave up after 4 months wait.
Apr 28, 2011 | Behringer Ultratone K1800fx 180w Keyboard...
I have a Mackie d8b, not getting any signal no matter what we try.
This is vague,,, there are so many outputs, knobs, LED's that I suspect you have not tried the right combination. I have no idea what your signal sources are... mics... tape... etc.
To start, turn the trim control of one channel that you have a signal source connected. Set all the EQ controls and the pan CONTROLS TO 12 O'CLOCK.
Check that you can trigger the clip light with high level of input. Press the solo button for that channel and using a set of headphones listen for any signal... turn the headphone level up and the slider for that channel...
First do your basic checks,,, try EACH mute button and see the LED light... try each solo button and see that each will light AND also that ANY solo light will cause the RUDE solo light to come on...
Dec 09, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Mic output of my pmp3000 is weak,levels must all the way up to get any mic sound louder,Im using balanced xlr's for my mics, Is there any adjustable sensitivity adjustment inside the mixer? like the one...
Some mics will require the trim gain to be full on. Check the mic gain by pressing the PFL for each channel and set trim to be below the clipping level with maximum vocal into the mic.
There are some low output mics that may be inadequte as far as output goes. Shure SM58 are industry standard mic... If you don't have one to try, borrow one to test with.
After that, the slider, EQ controls and the MAIN sloder has all the control.
Sep 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
What sound does the low mid suppose to give?
When terms like "low-mid" are used, it generally means frequencies between approx. 125Hz to 315Hz.
Apr 25, 2010 | Fender Rumble Series 100/210 100watt 2x10...
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Looking for sliders for mackie 1402 vlz pro how much are they?
You can purchase the channel faders directly from Mackie Service Dept., you can replace them yourself if you're good at soldering - HOWEVER, be advised that disassembling the unit to get at the faders to replace them will require a lot of time and patience if you've never done it before. If the faders are not moving smoothly, it's possible that the wrong type of cleaning spray was used on them and there's a possibility that they could stop moving and controlling sound.
Jul 27, 2009 | Mackie Music
Mackie cfx20 mkII compact mixer Logo
42 people viewed this question
Top Mackie Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
