Question about Motion Computing M1400 Tablet PC
The usb port on my camelio is pushed into tablet.
    Master:
  • 388 Answers
The USB port has broken off its mounts. You will need that repaired.
Posted on Apr 15, 2014
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Jul 11, 2016 | Tablets & eReaders
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
It won't charge
your kids messed up the charging port most likely plug it in and push the usb male end up twords the screen side and see if the red light in d corner comes on if so the micro usb port on the device needs repaired
Mar 12, 2015 | Tablets & eReaders
How do I unlock camelio vivitar tablet when I forgot the lock pattern?
You need to factory reset your device. to do this please follow the video instructions provided below.
Jan 14, 2015 | Tablets & eReaders
How do you fix a vivitar camelio if its screen is white
hello have you had a look on google how to do a hard reboot or youtube may be, or yr tablet will have a reset hole, very small in the side of yr tablet ,when turned on put a thin pin into the hole and press gently and you should feel it click,if this fails then hard reboot.
hope this works for you
Aug 11, 2014 | Tablets & eReaders
How to reset Prontotec 7 Inch HD?
Hi
Do you mean reset the Tablet? These Tablets don't have mechanical HHD they are IC's.
If you want to reset the Tablet to factory settings use a small stiff wire such as a paper clip, eye end of a sewing needle. Push it into the small hole between the earphone & HDMI sockets on the side of the Tablet. Push the reset button to reset Tablet
May 20, 2014 | ProntoTec 7 Inch HD 1024x600 Capacitive...
Vivitar camelio
My device usb port was pushed in to the device, how do I get it repaired?
Feb 24, 2014 | Tablets & eReaders
We need a plug
The charging on the tablet depends on the model.
Most including the Kocaso 776 charge via the micro USB port, and this is a standard USB port.
So all you do is purchase a micro USB to standard USB cable and plug it into the standard USB port on the charger or a PC.
Feb 07, 2014 | Kocaso 7" Capacitive Touchscreen Tablet...
Hello! I have ViewSonic 10. It cannot see an external HDD. It was correctly (I suppose) formatted but anyway the problem exists. It sees a USB card ok.
The problem is that the Viewpad 10 does not have enough power at the USB port to push a standard external HDD. You will need an externally powered drive or a two to one usb cable for this to work.
Jul 08, 2011 | ViewSonic ViewPad 1000 Tablet PC
Motion Computing M1400 Tablet PC Logo
121 people viewed this question
Top Motion Computing Tablets & eReaders Experts
k24674
Chris Larocque
dante
Are you a Motion Computing Tablet and eReader Expert? Answer questions, earn points and help others
