Question about HP Officejet Pro L7650 Printer
HP Printer test pages print out magenta. No yellow, green, or red shows up on another test page. Magenta streaks appear in a lot of my color printed documents.
Cleaned print heads, attempted to change out to new print heads, but alignment issue occurred. I cleaned old print heads and alignment corrected itself, however I'm still getting a significant amount of magenta on all my self test pages.
  • 300 Answers
SOURCE: Magenta print out very light
This is caused by dust in the scanner assembly. There's a fan right by the magenta laser scanner that blows dust and particulate matter in the air directly on that laser scanner.
Requiring its removal and careful cleaning of all lenses and mirrors. Unfortunately, this is not covered in the service manual. Getting the laser/scanner out is not too bad: Start by removing the printer covers, the rear plate, and the plate on which the DC controller and formatter mount. Remove the four laser/scanner unit corner screws and the single screw for its cover. Be careful to remove the small shutter spring on the cover before removing the cover. Use a strong flashlight to carefully examine the copper-colored mirrors for dust. Use dry cotton swabs to carefully clean all dust from the mirrors and the lenses. Blow dirt and dust from the inside of the scanner box. You will notice that the bottom mirror, facing up, is the one with the most dust.
Posted on Jul 23, 2008
futureloginn
  • 734 Answers
SOURCE: HP Photosmart 3200 All-In-One not printing yellow
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Posted on Dec 04, 2008
yooperbud
  • 8637 Answers
SOURCE: I have hp8250 photosmart printer
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
websnail
  • 419 Answers
SOURCE: A blank page when coping or printing in black.
As with all of the solutions I've provided on this and the other HP88 printers, the problem is that the black printhead has become clogged due to the conditions the printer is kept in.
For some reason the pigment black ink in the HP88 printhead is particularly prone to clogging when used in hot, dry conditions where there is air conditioning or similar...
The only solution I have found to date is to replace the black ink with a dyebase alternative and use that with a new printhead. Finding this solution took me about 14 printheads and a lot of head scratching so it wasn't easy...
Finding a dyebase alternative may be difficult but whatever you do, make sure you purchase a remanufactured original HP OEM, not one of the all plastic designs with no black rubber bulb in the bottom of the printer. They fail and leak a LOT!.
Hope that helps..
Martin
Posted on Jul 11, 2009
  • 89 Answers
SOURCE: I have an HP Photosmart 8250. I changed the
please if you are not professional technician then don't do this.but you can use some cartridge head cleaning solution.on the print head.if problem not solve then replace the cartridge.
Posted on Jan 12, 2011
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
Hp 3600n laster printer has started printing pink blothes on pictures
You probably have a defective magenta cartridge. To test that you need Print Test Quality pages.
1. Press Menu to open the MENUS.
2. Press to highlight DIAGNOSTICS, and then press .
3. Press to highlight PQ TROUBLESHOOTING, and then press .
The message PRINTING... PQ TROUBLESHOOTING appears on the control-panel display until the
printer finishes printing the PQ troubleshooting pages. The printer returns to the Ready state after
the pages it produces are individual colors, black, magenta, yellow and cyan and a white page and a config sheet.If the defect is on all pages then it might be a bad transfer belt. If it is only on one of the color pages, that will tell you which cartridge is bad.
Mar 11, 2011 | HP LaserJet 3600n Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
I have a HP Photosmart C5200 - pages are printing pink and red streaks in pictures
the print head for magenta and cyan (might be also Yellow) is dirty. you can try to clean it with warm water, or replace a new print head.
Jul 31, 2009 | HP PhotoSmart InkJet Printer
Magenta Ink Streaking
that printer color cartridge is a problem... buy a new one.... color ink
Jun 16, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Colors are uneven, too much green on the right side and too much red on the left
The internal optics are dirty. It's a known problem that HP's been ignoring.  More info is here:  http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1202453734788+28353475&threadId=1073731
Detailed instructions are on this page - look for Don Thompson's posting at Sep 15, 2007 23:38:51 GMT and click the papercliip to see the procedure. It's not for the faint of heart.
Dec 12, 2007 | HP Color LaserJet 2600n Printer
My Canon i960 printer is printing red streaks on the pages
It's possible that the heads need to be replaced. That's one disadvantage to the printers that don't have the heads contained within the cartridge.
Feb 26, 2007 | Canon I960 InkJet Photo Printer
HP Officejet Pro L7650 Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
