Question about Dishwashers
Hotpoint lft 114 uk
Not filling, 1st three lights flashing
  • 1,511 Answers
The circuit board may have been compromised or the in/out valve may be damaged or closed. There is an electronic valve called a solenoid that takes its orders from the circuit board. If the board is inoperative, the valve will not function and allow water to enter from the water soutce.
Posted on Apr 15, 2014
  • Tracey Chapple
    Tracey Chapple Oct 25, 2014
    The water inlet solenoid is not getting power to it
3 Suggested Answers
SOURCE: Just installed Hotpoint Dishwasher model LFT 114 uk
I'm having exactly the same problem, was this ever resolved?
Posted on May 10, 2010
heatman101
  • 43501 Answers
SOURCE: hotpoint LFT 114 dishwasher......why is it
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Aug 19, 2010
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3293-hotpoint-fdl-series-dishwasher-fault-codes
Jul 15, 2017 | Hotpoint Washing Machines
Hotpoint aq7L149i washing machine flashing lights ?
Hi Jason.
The most likely reason for your problem is that the water inlet valve is faulty. This is why the machine won't fill.
It is a simple fix for a serviceman.
Good luck.
Nomess
Nov 21, 2014 | Hotpoint Washing Machines
Lcode 1 flashes and drain pump doesn't stop
The flash code means there is water in the base panel underneath appliance first check the support on your lower arm isn't loose then leave to dry out
Jan 01, 2013 | Hotpoint-Ariston LFT 321HX Dishwasher
Flashing pre-wash approx 1 hour into wash cycle instead of moving onto rinse and wash. Whats causing this? This is happening on the WMA50.
Hi! If the pre-wash light flashes it means you are not getting enough water in the machine, check the pressure chamber, pressure switch, fill hoses and valves. For a workshop manual on the WMA50 which includes fault finding, visit www.selfix-uk.co.uk
Feb 17, 2011 | Hotpoint WMA50 Front Load Washer
Hotpoint LFT 114 dishwasher......why is it suddenly not getting any water? the pipe connections seem fine and it's worked for years!
heatman101
Aug 19, 2010 | Hotpoint Dishwashers
My Hotpoint Aquarius WF440 fills up fine but will not move on to rinse and spin. Engineer been out and says its the heating element. He has asked me to wash on no heat until part arrives. Since then every...
I am fairly confident that the problem is entirely due to the fact that the heater is not working.
You are going to have to wait until the new heater is fitted beore being able to tell if there is another fault.
Hope this helps.
Dec 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Flashing on/off switch flashing energy saver light
I had the same problem with our hotpoint aquarius WT540P , I contacted EMW electronics who told me it was most likley the Computer board. They supply reworked replacedment boards on an exchange basis. I installed the replacement and the machine's been washing away merrily since. Here's a link to there web site. http://www.emwelec.co.uk/ .
Regards.
Nigel
Apr 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wd420
Check if the hose from the tub to the drain area has come off; refit carefully. This could happen if the tub is unbalanced, happens sometimes.
Pl rate if helped..................
Dec 28, 2007 | Hotpoint Aquarius WD640 Front Load...
Dishwashers Logo
97 people viewed this question
Top Dishwashers Experts
