Question about Garden
Appears oil is blowing out the air intake.
I just started my trimmer and noticed when I give it some gas it blows smoke and sputters, then dies. I take the air filter off and it is soaked with oil when previously it was dry. I pull the spark plug and it is dripping with oil. I clean it and the same thing happens within a few seconds of starting.
  • 1,511 Answers
If the tension screws are tight and the oil spills or leaks out, then the metal housing may have a fissure, a fine crack when under pressure spews out oil. A cracked head is replaceable.
Look for leaks from any seals also.
Posted on Apr 15, 2014
Cranks but sputters, blows grayish/white smoke, and I do smell gas in the oil. What could cause this?the blades it cuts off.
do not run or try until you change the oil . sometimes the float sticks in the carb and fills the crankcase with gas . I like to add an inline shutoff valve .
Aug 28, 2016 | Garden
1998 gmc sierra 1500 5.0L
white smoke is a blown head gasket [white smoke burning anitfreeze]
Jun 24, 2013 | Cars & Trucks
I have a 93 Mercury Tracer with a Ford 1.9L engine. About 2 months ago it started idling high and low when I am parked or at a stop light. After checking my air filter, I noticed that it was sucking oil...
put a can of seafoam in your fuel tank at your next fill up after doing the following
replace your pcv valve
replace all the loose, worn, broken, or missing vacuum hoses one the entire engine
clean the air breather tubes, the whole air cleaner, and if necessary the air filter
that should do it for you
Apr 08, 2017 | 1993 Mercury Tracer
Speraticly keep losing a cylnder and when it does it really loads up on fuel spits and sputters dies and blows white smoke
White Smoke -- is Coolant & a Bad Head Gasket
Do a Cylinder Leak Down Test & a Combustion
Leak Test
Nov 26, 2012 | 1987 Ford Ranger
I have a Craftsman 650 series lawn mower. It starts but sputters and smokes and finally dies. I replaced the spark plug and checked the oil but it did not help. What do I need to do now??
I have a similar issue in that my Craftsman 650 in that it sputters and smokes out of the muffler and spits oil out from there as well. It does not die, but I cannot operate the lawn mower with all the smoke and oil blowing out. Plus, I get oil leakage on the deck of the lawn mower (top). What would I check for here?
Nov 17, 2009 | Craftsman Garden
Ford f250 diesiel sputters blows black smoke dies
youll think im crazy but change the oil and look for a oil leak, prob around the fuel filter
Jun 14, 2009 | 2004 Ford F250
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The cars starts sputtering and then dies
the car starts sputtering and blowing smoke
the oil is find
it is 1998 buick lasaber
Oct 20, 2008 | Hyundai Sonata Cars & Trucks
Blowing white smoke
how much white smoke? white smoke usually indicates a headgasket
oil should not be black that quick
Sep 23, 2008 | 1998 Mitsubishi Eclipse
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
