Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool ED22DQXEW01 Water Dispenser Problem
The other day the ice and water dispenser was working fine, then this morning when I went to get my daughter a glass of water, no water came out. I can hear a humming like it's trying to work. I emptied the ice bin to see if the icemaker is still working, still waiting on that. I unhooked the water line from the fridge, and the water's running fine through that along with the filter (it's inline attached to the water line on the outside) Any suggestions??
  • gypsyfiresto Jun 19, 2009
    Even if the icemaker works? I just checked, and it's still making ice just fine? Only the water dispenser.
  • 35 Answers
CHECK WATER FILTER/// IF GOOD BAD WATER VALVE
Posted on Jun 18, 2009
Frs26zrg - water & ice dispenser stoped working
There is a small water pump at the back of the refrigerator. As soon as you pull it out you will see it just replace it and should be fine
Dec 22, 2017 | Refrigerators
Double door whirlpool refrigerator with ice and water dispenser on door. The problem is that the ice dispenser seems to freeze up and therefore does not come through door. Everything else works fine. Any...
yep that is a systemic problem with that fridge, you need to pull the ice bucket out about once a month or so, empty and clean. I suggest you do this just before you go to bed that way you have ice the next morning. this is just maint.
Sep 03, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Water dispenser does not work, ice maker does work. This is a used Whirlpool side by side. I hooked up the water yesterday and the water dispenser worked. Overnight, something went awry and I do not get...
Icemaker is in line with the water and runs from the icemaker threw the door and up to the water valve. So that is why the ice maker is working and the water is not working, most likely the water has frozen inside, And this can be caused by many different reasons, if it has been humid or the door was left open then shut it would cause the moisture in the air to be drawn to the warm water and flash frosted the pipe, try to see if you can defrost the line with a hair dryer. If that does not work post here and I will tell you the next step to try.
Aug 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Door Ice Dispenser Not Working
mine froze up in the shute, had to put water down iti
Aug 26, 2009 | Whirlpool GS6SHAXLS Side by Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My Whirlpool ED22DQXEW01 Water Dispenser was working just fine, when one day it just stopped. I could hear humming so it was trying to dispense water, but nothing came out. The icemaker was still getting...
The humming noise is a defective coil that opens the water valve. When they weaken that begin to vibrate and hum because they don't have the strength to open the water valve. The replacement part number is 2188542. Let me know if you need any more help Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
Jun 24, 2009 | Refrigerators
Water dispenser stopped working.
if your ice maker works fine then its going to be your solinoid valve thats bad oin the dispenser.
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
393 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
