Question about Brother Mfc-j270w All-in-one Inkjet Printer, Perfect Working Condition
Feed but will not print - Brother Mfc-j270w All-in-one Inkjet Printer, Perfect Working Condition
  • Brother Master
  • 783 Answers
We ended up using the printer with the smaller, manual feeder that you would also use for longer paper, on the front of the machine when you open the grey door. It held several sheets. Then we replaced the printer with a similar model. I believe I found some information onine that led me to believe it was not repairable.
Posted on Apr 15, 2014
Reversing Labels before Printing
It's called "Present Distance" and it can be set to "0" in the printer's control panel. Look under Print Control.
Jan 21, 2014 | Datamax Office Equipment & Supplies
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
I have a Dell 5210N mono printer. And I want to use the manual feed tray as a second paper drawer for letterhead paper only, ie leave a whole stack of paper in the manual feed. Then when I select manual...
Check the software provided or installed on your Computer you use for work(printing software), look for print properties, check for print settings, look for manual Feed, Under manual Feed, set it for letterheads, however this has to correspond with the Applications you are using to print letterheads out of( under print, into the preferrences you should be able to have the settings as well). If your printer software does have these settings, then you will have to do it Manually upon every print.
Dec 03, 2010 | Dell 5210n Laser Printer
PRINTER SAYS 'PAPER EMPTY/ LOAD PAPER' -- BUT SHELF IS FULL. WILL NOT PRINT/ FEED PAPER
IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
May 29, 2010 | Canon iP4700 InkJet Photo Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
Not printing
Please open the manual feed and try to print using manual feed if you are able to print fine using manual feed that check pickup roller of Tray 2.
First of try to print using Manual feed and let me know if it is printing from Manual feed or not.
Jun 30, 2009 | HP LaserJet P2015 Printer
Dulex printing???? for HL 2040
The way that I know to do it is to indicate that you are going to manual feed when printing. hit print
Then feed the paper into the manual feed slot, noting the correct direction in the diagram in the paper feed area. Once the first side prints then feed the paper through the manual feed slot, again following the directions in the diagram.
Feb 13, 2009 | Brother HL-2040 Laser Printer
Paper feed
hi, do you notice any intake activity when u hit print in word etc???check word print properties.. let me know
Dec 09, 2007 | HP DeskJet 820Cse Printer
Brother Mfc-j270w All-in-one Inkjet Printer, Perfect Working Condition Logo
24 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
