Question about Garden
I have a craftsman chain saw model 358350280 i need carb adjustments i cleaned it but need to know where to start with screws one is red one isblue. thanks to all who help. dave
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
The screws are for high and low. Start by tighting the screws . Then unscrew both about 1-1/4 turns. Work on one at a time. Get the high adjustment dialed in first, then work on the low or idle.
Posted on Jun 19, 2009
Settings for carb. on a 42 cc chain saw
Initial settings are one full turn CCW on both low and high side adjustments.
Sep 02, 2014 | Craftsman sears 18" Chain Saw Chain (...
The chain keeps coming lose and falls off
Make sure chain tension on the bar is correct and then the 2 nuts holding the bar is correct, Youtube has alot of videos on how to set chain tension as well as the Oregon website
Aug 27, 2014 | Craftsman sears 18" Chain Saw Chain (...
Craftsman 16"what is the starting carb adj
Gently turn both carb screws in all the way. Then turn each out one turn. The fast screw is marked with an H and the slow is marked with an L.
Jun 25, 2014 | Craftsman sears 18" Chain Saw Chain (...
Can't start chainsaw
Walter:
gently run the fuel and air mixture screws on the carburetor all the way closed (clockwise).then turn them out one and a quarter turns each. That setting should allow the saw to start if you are getting fuel to the carburetor. Once the saw starts, make fine adjustments to the fuel/air mixture screws until the saw runs to your satisfaction.
Jul 13, 2013 | Craftsman sears 18" Chain Saw Chain (...
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
How do you set the carburator back to factory specs. mine wont keep running
Basic settings can vary from model to model, a good starting point for most carbs is screw both H and L screw right in ,then back the H screw out 1 turn and the L screw 1 and1/4 turns, the machine should run well enough to fine adjust from there, they are both fuel screws, so the more you unscrew them the richer the saw becomes, always remember if there in another under lying problem adjusting the carb screws will not always help, before any adjustment clean or replace the fuel filter in the fuel tank.
Feb 03, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My chain saw will not start. I gave it to a guy who messed up the carb adjustments. Need to know the initial carb setting.
Turn both jet screws CW to stops (lightly), then back each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Start the engine and allow to warm up, then pull the throttle full on. Turn the H needle CW until the engine starts to speed up, but still 4-strokes. Correct adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle so that the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jul 11, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Need carb setting wont idle runs in spurts
There is usually a sticker with a craftsman Model Number on it, often "358.Something". That number can be used to find an IPL and if you are lucky an OM here: Sears PartsDirect http://www.searspartsdirect.com/partsdirect/index.action Start at 1.5 CCW from lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 19, 2010 | Poulan Garden
10 year old craftsman chain saw14 or 16 inch sears craftsman
Duplicate Post
Lou
Duplicate Answer
Feb 19, 2010 | Homelite Garden
Garden Logo
128 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
