Tv won't turn on
I have a GPX 23 inch TDE2382B tv and it won't turn on. I have only used a hand full of time times and the last time it was used was when I put it into my nephew's room so that he could watch tv that night and the next day, it wouldn't turn on. I have no clue what is going on and I have followed all the proper directions for using the tv.
    New Friend:
  • 113 Answers
Are you using a remote, or try to turn on manually. If your remote does not work, it needs to be programed to your t.v. And all remotes and t.v.s have different codes. Sometimes your cable provider will help you program your remote, or reset your cable box. My remote for my cable was not programmed, so I had to read the instructions myself to get the remote to work with the cable box channels.
Posted on Apr 17, 2014
SOURCE: Code for Direct TV remote control
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Best of luck
Posted on Dec 03, 2007
  • 30 Answers
SOURCE: Daytex tv/dvd combo..Dvd won't play movies.
have you tried cleaning the disc you are wanting to play
Posted on Sep 05, 2008
  • 276 Answers
SOURCE: I have a 20 inch TV/DVD combo 20HLV15. Last night
tiene que revisar el cable de AC de corrient ey si esta bueno tiene que de sarmarlo para que revise lo que es fuente de alimentacion de su tv combo
Posted on Aug 24, 2009
  • 88 Answers
SOURCE: I have just bought the Bush combi A322d hd ready
Is your antenna "omni" or "uni" directional? "Omni" means you won't have to aim the antenna but "uni" antennas have to be pointed in the direction the nearest tower/s. You'll want to go to AntennaWeb.org and enter your address. This will show you locations and distances of TV towers in your area. My location is over 39 miles from any tower so I get virtually no reception with regular HD antenna. If your more than 20 miles you'll need to get a fairly high gain antenna and have to aim it in the direction of the TV tower.
Posted on Nov 19, 2009
  • 902 Answers
SOURCE: I have an apex flat
unplug the tv and the direct cable box reset the box by plugging both the tv and box back in. MAKE SURE the tv is set on the right input for the box first. if the tv said to do auto scan then you lost the connection from the box either by changing the input that box is connected to if by a cable its usually 3 or 4. if by hdmi or rca cables its an input channel. also make sure not cables are loose try that first before unplugging the tv let me know
Posted on Mar 16, 2011
I have a GPX TV/DVD Combo Model# TDE2382B that won't come on. I have a standby light but when I turn on the TV it turn offs back off after 3 seconds.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
In most cases, the main board might have to be replaced.If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first.If it does not help you, replace the main digital board.There are two methods to reset TVs.The first is simple to do; a Hard Reset.The other is somewhat skilled; is a Factory ResetF (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset.If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option.If you wish to get some details; visit the site linked here.
Jul 28, 2016 | GPX Televison & Video
Screw size for wall mount 32 inch model TDE3253
Bolt size is M6 bolt pattern and thread pitch. A 15 to 25 mm long bolt is recommended depending on the thickness of the wall bracket.
I got got this from GPX. If you email them you can get the full TV guide.
Apr 18, 2014 | GPX TDE3282B 32" 720p LED HDTV/DVD Combo,
Free tv repair advice
If the screen goes normal I wouldnt worry about it too much. I would definitely have it looked at as soon as possible. Sounds like a power problem inside.
Sep 09, 2013 | Televison & Video
GPX 1510. Ha ving trouble with the power. It flashes a green light with no picture. It has done this a handful of times but always came on..not this time..it flashes green abt a dozen times and then...
Will ur tv the power supply board finally completely gave out.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Aug 22, 2011 | GPX TD1510B 154 in LCD TV
We have a new 60 inch LED Sharp TV. Will an APC #BN600R battery backup, 600 VA 360 watts, handle a power outage or surge for this TV and a Dish network DVR??
Yes this UPS will protect the TV and the DVR.
The TV is pretty energy efficient, and uses just under 100watts powered on. The DVR uses under 30 watts, so under heavy load you won't go over 150 watts if just these two devices are plugged into the battery backup side of the UPS. I'm not sure how long this UPS battery last's in a power outage, but since you are not using it to the full 360 watts, you should get double time out of it, though of course, its best to power off your devices as soon as you can. Regards, Chris
Jul 12, 2011 | APC BN600R Battery Back-up 600VA UPS...
46 inch Samsung HD clicks but won't turn on. First notice several weeks ago when using remote to turn on tv, it would click a few times and come on. Over a period of time, it would click for longer...
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jun 25, 2011 | Televison & Video
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
I have a 32 inch tv, the picture only shows 23 inches
This is the tv station only broadcasting a certain size for the video. One way you can fix this is going into the menu and looking at zoom options. I use it all the time on my tv. If this doesn't work, call your cable company or your tv's manufacturer.
May 22, 2011 | Televison & Video
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
