Question about Golds Gym XR 5.9 Slant Bench
Replacement pads please
Where can I get replacement pads?
My screen wont work or let me unlock it for my pendo pad
please confirm if your pad has enough power and chceck if the power light are on if they are on you need to open your pad to confirm the cacle that attaches you screen to the pad is okay and if it is okay replace your screen with a working one
Oct 26, 2014 | Computers & Internet
Rear brake pads
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
How to Replace Install Inspect Brake Pads on Harley Davidson Guide...
Sep 11, 2012 | 2006 Harley Davidson FLSTN Softail Deluxe
Replace brake pad light on, how do you reset it?
you need to replace the pad wear sensor when the pad wears down it wears the sensor and the sensor needs to be replace if you look at the sensor you can see the wire on the sensor wears threw
May 19, 2012 | 2009 Audi Q7
Eee pc left and right click not working
Please check with external Mouse.. if it working fine there may be problem with touch pad. Please reinstall the drivers of the touch pad and check once. Even the prolem exist, check with local hardware repair shop for touch pad replacement.
Hope this helps.
Jun 28, 2011 | Computers & Internet
Touch pad inoperaive on one side
about the only thing you could do is to replace the touch pad there are no repairs done to touch pads we basically just install a new one i suppose one could take one apart and try to fix it but there are no schematics that they give to the touch pad make sure before ordering a new touch pad that it is the touch pad and not the control board that has malfunctioned if you are unable to perform these tests please call a repair technician if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 13, 2010 | Microwave Ovens
My asus K40 series laptop all of a sudden lost the touch pad (mouse pad). I have to use the external mouse through the USB port....can anyone assist please?
seems you need to replace the touch pad, if you have warranty on it return it and have them replace the touch pad
Sep 27, 2010 | ASUS Computers & Internet
Ho do i replace my a4 2004 front brake pads
IT IS VERY EASY TO REPLACE FRONT PADS IF U WANT ME TO WALK U THROUGH IT REPLY BACK EMAIL BIGGSONNY@GMAIL.COM
Apr 26, 2010 | 2004 Audi A4
I am receiving the same error message on the display window
Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Function key shorted or stuck :
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Sep 12, 2009 | Maytag MER6769 Gemini Electric Kitchen...
Brake wear sensors
Redmondeo34
A couple of things to check.
This is only if you replaced the front pads, after the warning light came on.
1. Make sure brake fluid is level and at the max mark
2. Did you replace the front pads sensors with the new pads.If not please do.
3. Check that the rear pads and sensors are not worn and do not require replacing.
4. If all above is good, Drive vehicle for about 5klm and switch off and on it will reset itself
regards
I hope this helps.
Jul 03, 2008 | 1996 BMW 318
Golds Gym XR 5.9 Slant Bench Logo
60 people viewed this question
Top Golds Gym Exercise & Fitness Experts
Steven's...
Steven's...
Sock Puppet
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
