Question about Amana Modern Maid Downdraft Stove With Grilling And Burners White
Oven button will not engage
I can not get the oven to turn on the button will not engage
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Remove the knob/button and look inside if it is split it won't grip the shaft and needs replacing.
Posted on May 25, 2014
How do I turn off the "key" icon on screen display Heartland Stove/Oven ?
The key is a lockout symbol. It appears when you set the oven to child lock mode ( Stops kids from opening the door and getting burnt) or when the oven gets over a certain temperature. (Stops you getting burnt) If you from have the instruction manual, it is xa bit difficult. You usually have to npress and hold 1 or more of the buttons in for a few seconds to unlock. I'm not sure which ones on your oven.
Jan 02, 2016 | Heartland Appliances 30 Inch Dual Fuel...
Top main burner want turn off
Switch is either bad in it or has food/grease build up not letting it shut off.
Unless its a newer model and is push button?
Nov 12, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
How to turn off oven light
THERE IS A LIGHT BUTTON..... IF NOT.... THE SWITCH ON THE OVEN DOOR ISN'T MAKING CONTACT OR IS OPEN.
Oct 28, 2014 | Cooktops
Frigidaire stove oven want come on model # FGF368GSJ
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Nov 06, 2012 | Frigidaire Stove/Oven/Range Cooktop -...
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    I don't know how to start the self cleaning oven! I don't have a manual and I don't see any buttons that indicate start self cleaning oven!
    there should be a button a small button that says self cleaning on the oven mines on the side but just look almost 95% of all ovens have this
    Mar 10, 2010 | Whirlpool Cooktops
    Whirlpool self cleaning oven Accubake. 2 yr old
    Hi
    The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
    Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
    If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    Jul 06, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
    Hob not working
    It is child lock.
    Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
    To turn child lock off switch on hob, and touch - for 5 seconds.
    Sep 16, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
    Oven Clicking Noise
    Sounds like you've got the igniter button stuck IN. If so it will probably carry on clicking until the battery runs down.
    The battery might be behind the bottom drawer. If you take the battery out and the clicking stops then the striker button is probably glued up with something. Just clean it.
    Oct 06, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
    Amana Modern Maid Downdraft Stove With Grilling And Burners White Logo
    118 people viewed this question
    Top Amana Cooktops Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    paulcarew
    Are you an Amana Cooktop Expert? Answer questions, earn points and help others
