Question about Avermedia Avervision 300af+
Will not turn on even though we have traced the power source, changed the power source and still will not show power
Why my tv shut offf sometimes and then turn on ??
Many of the newer type televisions develop power supply problems, and even though problems vary from make and model, many can be traced back to power supplies. The most common troubles stem from capacitors that are on verge of failing or have failed when set will not power up or will power up, shut down on its own, etc. I do not recommend owners repair their own sets due to high voltages and the level of knowledge needed to tackle such a job. There are though companies that supply capacitor "kits" for many makes and models, so if service tech traces to capacitors most are available. First though weigh the cost of repair versus the cost of a new replacement.
Jun 20, 2014 | Panasonic TC-54PS14 54" HDTV Plasma TV
Why wont tv come on after switchin off at power point
It is possible your set was on the verge of failing when the sower was switched back on from the mains there may have been a "surge" which contributed to an early failure.
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
Whirlpool gold single oven - YGBS277PDB7 - The power failure signal has started to show up during cooking and everything shuts down even though there is power. what part would need replacing?
Turn the breaker off before you start. To isolate this your going to need to remove the oven from the wall. Once done, you'll need to remove the top of the oven so you can see down inside of it. Starting at where the wires come into the machine, you're going to trace the wiring to each of the parts in series. These parts include the thermal fuse, lock mechanism, wiring, etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 22, 2012 | Whirlpool GBS277PRS Stainless Steel...
It won't heat up... even though there is a flame
Check The Power Source
If the gas oven won't turn on, the first thing to do is check the power source. Most modern gas ovens are electrically powered. Check to make sure the oven is plugged in and the breaker isn't tripped.
Check the Heat Source
When a gas oven won't heat, the pilot light can also be set too low; if the pilot is lit but the oven isn't catching, adjust the flame.
Newer gas ovens use electric ignitors that produce sparks. If the oven doesn't heat, the ignitor could be broken.
Feb 05, 2010 | Ovens
1988 subaru gl 1.8..no power to fuel pump, fuses and links are good. pump works fine with power probe, just not getting power to it..diagram shows black and yellow wire to pump. it is in fact a blue...
The blue wire changes to Blue/White. It gets power from the Fuel Pump Relay. Fuse number 11 is the power source. The relay is up under the dash panel, blue connector
Nov 04, 2009 | 1988 Subaru GL-10
Working fine until it got turned off at source. Now showing no power going to it even though it's plugged in
Turned it off for an hour or so then when I turned it on it connected and now no probs.
Aug 04, 2009 | Nintendo Wii Fit for Wii
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
Computer isnt running
If that is the case your system need to check the battery for fault and does it happen with the power source too i fthe same problem check your processor fan if its bad when you on the system and is not blowing that might have cause the processor itself to get bad you will have to change this ones and then your system will be ok right rate this solution.
Nov 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Avermedia Avervision 300af+ Logo
79 people viewed this question
Top Avermedia Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Avermedia Office Equipment and Supply Expert? Answer questions, earn points and help others
