Question about Canon irc5185i
SHUT DOWN my printer switches off with this error code, what should I do?
  • Canon Master
  • 783 Answers
If you have installed driver for your printer (and software) in your pc , go to control panel -windows firewall - put the settings - OFF , try to connect your printer again . Verify if your antivirus not blocked this printer ! Go to printer and faxes(device and printer) right click with your printer - set as a default printer
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Canon Printer Support
Posted on Apr 15, 2014
System error code 070010
07-00-10 error code refers to a drop out voltage warning,
basically this means something in the machine is shorting the power supply out,
the chance's are that the fault lies with the trailing cable where the laquer and white coating eventually wears down to reveal bare trailing cable connections which short to ground causing the power supply to temporarily shut down causing the formatter to display the error.
this is a very old model now and the chances of you being abble to order 'new' have allready gone. I would recommend upgrading to a newer model.
Nov 07, 2013 | HP DesignJet 750c plus InkJet Printer
How can i fix my C6180 HP photosmart computer with msg of improper shutdown from wall switch
Try what they call a hard boot. In other words completely power down ththe printer by either removing the power cord or shutting down via the power button. If this does not work try to enter the menu and clear the arror code manually. Hope this helps.
Sep 08, 2012 | HP Photosmart C6180 All-In-One InkJet...
E000021-0001 error code
The Canon Color Image RUNNER 3200 machine has two on and off switches. Facing your machine. One is on the right side and the other is on the back left side. Shut machine down. Wait for about 10 min.s turn switch on.
Feb 13, 2012 | Canon iRC3100 Printer
Power Failure in viewer. Paper now jamming also. Toshiba e-studio 352
double press the fc button the machine cannot be switvhed off at the power switch it must be shut down press energy save button and shut down what paper jam error codes does the machine give
Feb 17, 2011 | Toshiba e-STUDIO 352 Black and White...
The copier stopped working and Error code E000003-0000 came up. I've shut the machine down and restarted, but error code still comes up.
switch on the machine, press *(additional function) 2and8 together and again *, on screen select copier>function>clear>error>ok. switch off the machine and restart.still problem appears then check fuser unit.
Jan 26, 2011 | Canon imageRUNNER 2200
Error Code: 39,003.40:133671 Yesterday the copier/scanner would not work. I shut the printer down and restarted it and received the above error code. I shut the printer down again and restarted it and...
this is a scanner problem that can be associated with the scanner lock under the scanner bed. make sure the lock is in the 'unlocked' position. it is easy to move this when lifting the scanner bed to reload the ink blocks. if this does not solve the problem you may have to replace the scanner assembly. hope this helps.
Aug 19, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
I had a problem start with error code E000-0120. I easily found this was an overheating problem. The room where the printer was located had gotten very hot, so I shut the printer off and left it until...
these means that thermistor still reports the temperature problem or that copier was memorised the error code and keep reporting it. Auto shut off is sign of fixing trouble.
To be sure if the thermistor or lamp is faulty, first try under service mode to clear the error.
If that doesnt help you you need to call service to locate problem in fixing section.
Procedure to clear error:
Clearing E000
1) Start service mode, and select 'FUSER' under 'FUNC'.
2) Press 'E000RLS'.
3) Turn off and then on the power switch.
SERVICE MODE:
1) Press the "*" key on the control panel.
2) Press "2" and "8" on the keypad at the same time.
3) Press the "*" key.
Hope that helps!
Aug 10, 2010 | Canon CLC 4000 Copier
Printer cycles on and off continuously
make sure that the switch is properly pressed on and it pops out again.
Jul 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
Canon irc5185i Logo
old marine
old marine
