Question about Stanley Tools & Hardware - Others
My bostich sb-1850bn finish nailer fires about 6 nails then stops and does not fire anymore
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Paslode framing nailer intermittent firing
OK lets start from the top, gas full, but what is the expiration date, it is located on the bottom of the fuel cell and if out of date can cause a problem. Second when was the last time the tool was taken apart and completely cleaned and serviced with new orings and lube? Lastly look at the nails are they traveling thru the magazine freely? Let me know and I will try and help further
Posted on Jan 11, 2009
comax
  • 154 Answers
SOURCE: Mastercraft Brad nailer piston always fires
The dial on the top of the gun is most likely the depth adjustment for the nails, this should solve the driver damaging the work piece. Make sure the nails are the correct guage for the nailer you have.
Posted on Apr 14, 2009
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
mrhappyface
  • 205 Answers
SOURCE: senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
Posted on May 29, 2009
I have a Bostitch SB-1850BN air nail gun (brand new) I used it for about 4 hours last week and it worked fine. Went to start using it again and it won't fire a nail at all. Is their any fixes?
Hmmmmm he said wisely.
Wonder if it got adequate lubrication?
Wonder if there was water in the air supply?
Wonder if there is adequate air pressure now?
Wonder if there is a nail jammed in the mechanism.
Wonder if there is a manufacturers defect?
Old dude recommendation?????
I'd suggest that you bring the gun back to where you purchased it and let them look. Hopefully they will spot the problem and coach you through so that you will be a happy customer.
Cheers.
Oct 19, 2015 | Air Tools & Compressors
Bostitch SB-1850BN. I bought a bundle of nail guns over a year ago, today I go to use this gun for the first time and just get a very poor poof of air coming out, no nail. I've tried it with pressure in...
At the end where you attach the air hose is the nailer imprinted with the words "add oil"? If so; add a few drops of oil designed for air nailers.
Also check to make sure no nails are stuck in the tip of the nailer and the return mechanism is reset.
Oct 20, 2017 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
HAVE A SB-1850BN AIR LEAKS THROUGHT TRIGGER WHEN I TRY USE IT
replace the trigger valve,,use a roll pin punch to make it easier
Apr 22, 2013 | Stanley Air Tools & Compressors
Driver stays out after firing
You probably have a worn air seal. Or perhaps some pneumatic tool oil might do the trick. A few drops in the air outlet then bumb some nails into a piece of wood.
Apr 18, 2013 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
My Stanley Bostitch SB-1850BN brad nailer will not sink the brad. It leaves it about an eighth of an inch above the surface. Adjusting the head using the adjustment thumbwheel does not help. Any...
You may have a broken tip or bent driver. Remove tha nails from gun and dry fire into a piece of wood. You should see a nice little indention. If you continue to hold the trigger and the nailer against wood after firing, the driver will stay in the lower position for examination. Just fire into wood and keep gun against wood while holding trigger and lean gun to side untill you see the tip. If you see broken tip or no tip order repair kit that includes driver, or driver alone from www.bostitch.com or ebay. Good luck
Sep 07, 2010 | Stanley Tools & Hardware - Others
Bostich narrow crown air stapler won't work
before going about rebuild get can of carburetor spray cleaner and stray the ram area lots of times the glue that holds the staples/or nails builds up and stops up the ram rod spray the rod a few times than with air hooked up dry fire if it frees up lube rod area
Jan 17, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
I have a SB-1850BN Bostitch finish nailer that no longer shoots nails. I think it may be a o-ring in the cylinder but not sure. Is there an easy fix for this situation?
Generally speaking an O-ring kit will resolve this type of problem. Check with your local lumber yards that sell Bostitch products. They may have a Bostich Day at which, for a purchase of nails or some other Bostitch product, the manufacturer will give up to 2 tools a quick overhaul including replacing the O-rings.
Dan
Jan 11, 2010 | Stanley Air Tools & Compressors
Paslode shoots a few nails and quits
try a new battery m8 when they have been used fir a while they wear out at the catch and when u fire the nail gun the battery works its way out enuf to stop it making a good contact. Hope this helps.
Aug 11, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
May 20, 2009 | Stanley Bostitch BT200K
Tools & Hardware - Others Logo
37 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
