Question about Harman Kardon AVR 510 Receiver
Hum on all outputs even with volume turned down. any ideas?
I have also experienced sudden and abrupt volume changes depending on what option I select, ie dolby vs stereo it seems as though the volume gets reduced to the point that I have to turn it way up to hear and if I change it back it is extremely loud, this happens when I switch from HD on TV to regular channels, it is not my cable box, must have something to do with reciever
  • 81 Answers
Signal problem on box
Posted on Jun 18, 2009
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
LOUD HUMMING NOISE COMING FROM SPEAKERS
Could do with a service.
Check the turntable motor and drive plus check the cartridge and signal wiring.
Sep 14, 2017 | Wurlitzer Jukebox CD Player
Google: Randall Padilla, that's me.
What could be an issue is if the cabinet is a 4 ohm cabinet and you plug it into the 8 ohm output. of the RT100 ... IT WILL BE LOUDER that way... for a LITTLE while... till the power tubes get gassy from overheating and the sound will GO AWAY. VERIFY the impedance of the cabinet and plug into the correct jack on the RT100. Every RT100 will do this... it is GROSS abuse of the amp if you plug 4 ohm speakers into the 8 ohm jack. Some of the power tubes may conduct so heavily when they get gassy that they will cause a hum before total failure. The tubes will first get red, then orange plates and that drives metal ions out of the plates, then they get a purple glow and eventually blow the fuse or something in the power supply.
May 07, 2011 | Randall RT Series RT100H 100W Tube Guitar...
My Sony Trinitron volume goes from mute (1 bar) to loud (2 bars) - can increase to even louder but can't get low or medium volumes. The lowest volume is too loud for normal viewing. Any ideas about what I...
Hello
If you have some idea about the working of your TV, and some service experience you can do it by yourself. Your TV has electronic volume controls. That means, a gradual voltage rise or lower does the volume to go up or down. This voltage variation is done by an Ic which we call it as "System Control Ic", that every modern TV has; but differ in their type and number. You must know how to follow the schematic diagram of your tv to get the exact point from which the voltage orginates, and which point regulates the same.
At present there is some voltage, say 0.23VDC or so, remains at that control point even if you turned all the visual controls seem to be off; and that voltage suddenly goes up; say 3.05VDC or so when you adjust the volume to the near mid stage. Further saying 3.05VDC must come only after you have turned the volume bar to extreme high. Now you are listning your tv at is 1/4th volume at extreme low I thinks.
Looking for fault at system contol section must be done with patience, and should have schematic diagram of it, and some sort of skill. It is best for you to get service of an experienced service personal, otherwise the the faults will be rise in numbers. All sony tv has complex schematics even go to pages on a book, and have some difficut to follow even an experienced one you know. So think a little better and do the needy.
If you have confidence that you can reach the the above said points, contact me at my mail address which is given below. I will guide you. You must have the schematic digram of your tv also beside you. Ok.
gopakumarg43@ymail.com
Oct 19, 2010 | Sony FD Trinitron KV-28FQ75 28" TV
Very loud hummimg and crackling - even when volume turned down.
There are a few variants for this model depending upon the serial number. From your description, there are some capacitors in between the amp stages called coupling caps that are failing. The hum is some DC current being passed through the output stage. The crackling is probably just dirty controls.
Dan
Aug 18, 2009 | NAD Audio Players & Recorders
LG 47 External Audio Control
This is the only way a bose works
May 01, 2009 | LG 47 in. Flat-Panel LCD HDTV
Hum in sound volume
It could be a few things. The first thing you want to look at is make sure that the microphone is muted in the mixer controls of your audio cards. These settings are located in the control panel. If you need the mic, look under the advanced settings under it and disable the 20 db option for it.
If that doesn't work I have a few other ideas.
Mar 17, 2009 | Proscan 32LB30QD 32 in. LCD TV
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
Apr 07, 2008 | NAD C350 2-Channel Amplifier
The television has a loud humming noise.
change the power supply capacitor
Apr 01, 2008 | Televison & Video
Harman Kardon AVR 510 Receiver Logo
243 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
