Question about Canon imageRUNNER 8500 Copier
My DPC say NG in iR 7105
IR 7105 recently changed carona wires
4 Suggested Answers
  • 11 Answers
SOURCE: canon iR 7105
The Tray A Area Sensor Unit may be faulty. Replace the Sensor
Posted on Oct 28, 2008
Daniel S
  • 4323 Answers
SOURCE: error code for canon ir
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermistor. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 09, 2011
sodeep
  • 3267 Answers
SOURCE: ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
Posted on May 07, 2012
Hi, I want to know about Canon Image press 1110/1125/1135 these copiers use which type of toner. Can we put IR 5000 or IR 7105 toner in them How is the drum
no you can not, the toner in a image press is a dual component toner. in the 5000 and 7105 are a mono component toner please dont and if you did please tell the tech because it will drive him crazy trying to figure it out unless he is a veteran in the copier business.
Oct 17, 2015 | Canon Office Equipment & Supplies
Ir 7105 black copy is appear
I've had the Laser go bad on two occasions causing black or partial black copies
Feb 07, 2015 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Ir 6000 error code 0061-01
It just Need Cleaning (or change) of Primary Carona Wire
Nov 04, 2013 | Canon imageRUNNER 6000 Copier
Error code e121
Reader controler cooling fan fault replace the fan or dc board
Jul 17, 2013 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Canon IR 7095, error code E000005-010
Hello to all
I have a client server ir Pass has forgotten his password and I reset.
how reinitialiser server S2 canon ir Pass?
Thank you for the help.
Dec 27, 2012 | Canon Imagepass S2 Fiery For Ir...
My canon ir 7105 show E065 , i change the primary charger assembly still the same plz help me
E065 if you already change primary corona assy and the problem is the relay pcb , you can found it in the lower left side of the machine, i encountered it twice check if the fusible resistor is busted , if faulty u can jumper it using wire.
Apr 02, 2012 | Office Equipment & Supplies
Canon ir 5570
Replace carona wires or change primary charge unit
Feb 10, 2009 | Canon imageRUNNER 5570 Copier
We have a Canon IR-7105 which keeps jamming , then codes out with code Error E000069-00000 (the tech was just in and did a PM)
it is a transfer corona problem ,clean it first.even its not ok change the corona wires.
if its not ok finally change the transfer corona .
Jan 21, 2009 | Canon imageRUNNER 7200 Copier
The papers show white
The Carona wire is cut. ther are two carona wires one is Main charger carona wire and another one is transfer carona wire.
Transfer carona wire is at the botton of the copier when you lift the top cover
main charger carona is in the top. it is in the drum unit.
then other may be the developer is not there (insufficient).
toner and developer mixer may be less.
for further mail me at ramanathanr@integramicro.com
Oct 29, 2008 | Toshiba 2060 Copier
Canon iR 7105
Oct 27, 2008 | Canon imageRUNNER 7200 Copier
Canon imageRUNNER 8500 Copier Logo
14 people viewed this question
old marine
old marine
