Question about Daewoo DWC-121R Air Conditioner
Erorr code f6
The inside unit dont run
  • 11 Answers
F6 code on this particular model points to a problem with the internal fan motor
Posted on Apr 24, 2014
The compressor runs but the fan dont. The fan runs in heat mode only
fan relay is bad at inside unit(air handler) it has one circuit for heat and one for cold.
Aug 12, 2010 | Goodman CLJ30AR32 Air Conditioner
My central want come on inside or out dont even buss
Check all the circuit breakers first. Next, move the fan switch at the thermostat from auto to run. If the unit has power the fan should run. If it doesn't then start by checking the 24vac transformer. Let me know what you find.
Jul 18, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman Air (outside unit)
was there any refrigerant loss? "bumping" that results in movng usualy causes a leak.If the system is totally empty, It shouldn't start.. If it did major oh nos! will appear. Does it not start all? and was it running when it got thumped? May have to call a tech out on it. Sorry.
Jul 29, 2009 | Goodman CKL42AR42 Air Conditioner
No air blowing inside the house thru vents;starts fine than stops
You are likely low on charge and the unit is freezing up. You need some with gauges to check. You should not try to run this unit until then or it will burn out the compressor.
Jul 18, 2009 | Ruud Central System Air Conditioner
Brand new unit have 3 ton inside and out but unit runs all day and will not hold temp i run my ac on 76 but as the day get hot the temp inside will not hold at 76 ARS says they dont know whats wrong but...
call them back something is wrong if it is that new it is likely under charged. how big is your house square feet and what part of the country down south 400 square feet per ton if your house is more than 1250 square feet the unit is under sized since it is new did some body do a load calculation on the house if ya bought from a reputable dealer and you are getting no help call the manufacture. or the better business in your area good luck. Tom
Jun 29, 2009 | Weather King 10AJA3601AH Air Conditioner
2 to goodman ac unit model a24-08
Replace the fan relay switch in the airhandler(inside unit).
May 19, 2009 | Goodman Heating & Cooling
My ranai tankless heater is not working
Check the electrical supply to the unit but my guess would be an issue with the water flow sensor.
Mar 16, 2009 | Rinnai Water Heaters
Outside A/C unit
you should be able to hear the compressor motor running. if you dont hear anything its more than likely ists a control problem. is the fan running inside?
Mar 15, 2009 | Ruud Handle Air Conditioner
This is my first central heating and cooling unit the heat will come on and heat the house but the big fan inside the unit is not running like it did when we would run the ac is this normal
I assume you are reffering to the compressor outside not running. If so this is for A/C only. In fact once the cold is here to stay you should shut off the compressor "breaker" (located either outide next to unit or in fuse panel) and get a good quality cover for winter. This will keep the leaves and snow out of the unit. Just dont forget to take it off in the summer before you run the A/C or you will damage the system.
Sep 16, 2008 | Goodman Heating & Cooling
Airconditioner problem
This unit has a bad Start/Run Capacitor or a bad Fan Motor! Replace the $10 Cap...An then the $90 fan motor if the Cap dont solve it!
Oct 01, 2007 | Heating & Cooling
Daewoo DWC-121R Air Conditioner Logo
178 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
