Question about HP Laserjet M1319F Laser Multifunction Printer
Load paper Says to load paper when its full of paper
  • HP Master
  • 783 Answers
Go To Below official HP Printer Page For Your problem, Load Paper HP Support Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Posted on Apr 15, 2014
Why is it my printer is having LOAD PAPER when it is full of paper in area
Because the paper loading sensor is stuck in the position indicating no paper. Unstick it or replace unit.
Aug 19, 2015 | Canon imageRUNNER 2520 Laser Multifunction...
How do load paper in printer?
Load a stack of paper in the main tray: Load a stack of paper in the main tray. The main tray can hold and auto-load multiple sheets of paper. Load only thin, flexible media into this tray, because the paper bends as it passes through the printer.
I share a link please read full guide line, i hope solved your issue.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c00630201
Thanks,
HP Phone Number
Jun 18, 2014 | HP ENVY 5535 E-ALL-IN-ONE PRINTER
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Says needs to add paper but is full of paper
Hi claire fonte,
1- You might have the paper tray full, but be printing from a manual bypass, So Double check the paper setting.
2-If paper setting is correct then
probably you have to check the paper settings if your printer paper sets for legal and you have loaded some A4 SIZE in that case it will seek the balance size by asking you to load the paper .
if u can do the above you will not face this problem.
IF you got answer dont forget to rate me.
thanks claire
Mar 28, 2011 | Office Equipment & Supplies
Paper is coming out scrunched (folded) and sometimes torn at the top left corner.
Make sure the printer is clear of any paper jams and don't load the tray full of paper, load it 75% full but not 100%.
Feb 28, 2011 | HP LaserJet 3380 All-In-One Printer
When i replace with new original 818 color and black/white ink cartaiges the ink status show as b/w full and color iswith"x" mark(no ink) and printer can"t take paper i also re load the driver software
If there is an "X" on the color cartridge indicator then there is a problem with it. If you have removed the plastic tape that covers the part that connects to the computer and you still have this problem then the cartridge is defective and needs to be returned to the store and exchanged for another that is good. Exchange the cartridge and install the replacement. This should solve the problem with the printer not recognizing a full color ink cartridge.
You mentioned that the printer cannot take paper. Please clarify what happens when you load the paper tray and try to print? Are you loading paper one page at a time using the external feeder or are you loading the paper tray full with paper before trying to print? If your loading page by page or filling the tray with only a few sheets of paper then try loading a bigger amount of approx 1/2" of paper. It is easier for the printer to grab paper when the try has a good amount in it. If it still will not load the paper when the tray is full and inserted correctly, please advise what happens when you try and print - exactly? Does the printer respond to the print command sent from the computer? Does it make attempts to load the paper and then fail and stop? Does it pick up paper and then show a paper jam? Does the printer do anything when trying to print from your computer? Answer these questions and I will help you solve this problem right now.
Sep 27, 2010 | HP Deskjet 3420 InkJet Printer
Reads PC Load Letter even when full of Paper ???
That machine has a sensor lever that pulls a flag out of the way when paper is full. When dust and toner cover the sensor it can't tell when the flag is moved. It's best when you remove the covers but you can use canned ait and blow in the front area behind the paper tray and thru the hole that you can see around the black lever that moves when you load paper.
Jan 22, 2010 | HP LaserJet 4 plus Printer
HP Deskjet 690C says it is out of paper when it isn't.
Pretty well all printers come with two places to load paper: one paper tray and one feed tray.
Is the button on your computer or the setting in your word processor teling it to load from the other tray?
Sep 25, 2009 | HP DeskJet 690c InkJet Printer
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
HP Laserjet M1319F Laser Multifunction Printer Logo
94 people viewed this question
Seeker5211
Seeker5211
