Question about SVA-USA VR 17S 17" Flat Panel LCD Monitor
Mac Mini changed screen resolution monitor giving error message..
I changed the resolution in the control panel to the highest resolution (1024x768). The monitor immediately gave me an error message, something about 75mhz and said it was going to sleep. Whenever I hook the monitor up I get this message. How can I get in and change the resolution back?
PS I have time machine backups from before this problem. Are there any files in the system folder that I could copy to the Mac mini to fix it?
I am using an AGneovo F-15 at the moment.
Nancy
docnangee@yahoo.com
May be ur monitor is not capable to support such a kind of resolution or may be u need to update the graphics driver. if the problem still persists then visit the mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Posted on Jun 18, 2009
My Mac will not install the Digital camera Solution Disk says my screen resolution is insufficient...
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site; http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
May 04, 2011 | Canon A3300 IS Digital Camera
Compaq fs740 text too faint and fuzzy to read well
Firstly you need to switch to the monitor's optimal resolution of 1024x768 @ 85Hz and before anyone posts anything about resolution 1024x768 @ 85Hz is the optimum not the maximum. To change to this resolution: Assuming you are using Windows XP click with the right mouse button an an empty part of the desktop and select Properties (or click Start, then click Control Panel then click Display), on the Settings tab, under Screen resolution, drag the slider bar until it says 1024x768 and then click Apply. Also in Display settings you'll find an advanced button, in the advanced panel you'll see the option to adjust the refresh rate, try adjusting this to 85Hz. Now press the Menu Button on the front of the monitor and press + of - until you see an option called "Degauss" and press the select button on the front of the monitor, your screen will do a disturbing jump and flicker accompanied by a metallic thud, this is normal. If this doesn't help message back.
Aug 26, 2007 | Compaq fs740 17" CRT Monitor
How do I change the display resolution on the control panel ABOVE the maxed out resolution shown so I can use a 17' screen which requires 1280x10xx? When I try to use any 17" monitor, a message comes...
On a 17ins monitor the best resolution is 1024x768 regardless of whether it tells you a different "recommended" display resolution.
Just ignore any warning it gives you and it should work very well with the resolution i've told you, just use the slider to select the 1024x768.
Regards.
Dec 09, 2010 | Acer Aspire AX3300U1322 Athlon II X4...
The monitor is black with a error message :input signal out of range We are connected to a Mac Mini This problem seemed to happen after the monitor was accidently disconnected and then when it was...
Can you please get me the make and model of the monitor? Also did you check to see if the refresh rate of the monitor matches with that of the mac mini?
Nov 21, 2010 | Hannspree Computers & Internet
Monitor screen is almost completely black - i can only see the desktop very slightly. is there a light bulb that can be replaced to fix this?
Change the display resolution in Windows To change the display resolution to the highest resolution, use the following actions.
  • In Windows 7 , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows Vista , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows XP , click Start , click Settings , and then click Control Panel . Double-click the Display icon, and select the Settings tab. Move the slider bar until the highest resolution is set, and click OK .
If the screen is still blurry, please contact an HP support technician for further assistance.
Also see To troubleshoot this problem, make sure the AC adapter is connected. For specific steps, see HP Notebook PCs - Troubleshooting Black Screen Displays with No Error Messages During Startup or Boot .
Nov 02, 2010 | HP G60-127NR Notebook
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor lost resolution
itz probably corrupted software/driver or graphic adapter..
try reinstalling the drivers..
but 1st open control panel->display->click on the 'Settings' tab->Color Quality= (Highest) 32 bit; Screen Resolution= 1024x768 pixels (atleast)..
..try contacting ur system admin/vendor....
Oct 27, 2009 | Computers & Internet
I just bought an X223W Acer LCD monitor. The texts appear blurred on the screen. What adjustment do I need to make it sharp? Thanks.
You probably need to up the screen resolution.
Start/Control Panel/Display/Settings tab/Screen resolution.
1024X768 minimum.
While you are in the click the advanced button then click the monitor tab. Your refresh rate will most likely by 60 Hertz. Down below that you will see a "Hide modes that this monitor cannot display" check box. Check it. Now click the drop down arrow for the screen refresh rate. Set this to the highest setting there. This will stop the flicker that gives a lot of people headaches when they spend a long time at their computer.
Nov 29, 2008 | Acer Computers & Internet
SVA-USA VR 17S 17" Flat Panel LCD Monitor Logo
131 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
