Question about Altec Lansing VS4121 Speaker
Speakes too loud
Turn down speakers 2 notches
Reset timing belt light on quantum 2.5 diesel
Try this: 1. Put the key in the ignition and turn it up one notch. The dashboard lights will not turn on. 2. Hold down your trip meter button next to the odometer. 3. When you are holding the trip meter button down, turn your key to the next notch. So, the dashboard lights will be on, but the car will not be started. Do not start the car. 4. Continue holding the trip meter button until the light turns off. You have now reset your Maintenance Required, or Maint Reqd, light
Jan 02, 2014 | 2007 Toyota Quantum 2.5
I have a KLH ASW10-125C Subwoofer and a Harman Kardon AVR 3600 receiver. What should the setting be for volume, phase and crossover frequency?
Home Theater
volume - personal taste - usually just high enough that you notice the bass - try turning down until you don't notice it then turn up one notch in the switch
phase - depends on distance from other speakers - try initially setting to 0 degrees
cross-over frequency - depends on your other speakers - try setting at 60-100Hz
Nov 09, 2010 | KLH ASW10-125C Subwoofer
I changed oil on my 2006 Tacoma pick up, how do I turn off my maint light. Tks John
Try this procedure.
1. Turn the ignition key up one notch. (The dash lights will not be on)
2. Press and hold down the Trip Meter Button next to the odometer.
3. While continuing to press down on the Trip Meter Button turn the ignition key to the next notch or the "Run" position, the dash lights will come on but do not start the engine.
4. Continue to press down on the Trip Meter Button until the Maintenance Required light turns off.
The Maintenance Required light should now be reset.
Nov 06, 2010 | 2006 Toyota Tacoma
How to adjust bass and treble
this is kinda vague i hope this helps! first turn the equlizer to flat make sure eveything is equal. then turn he volume about 3/4 of the way up. this is around the point where th radiostartsto send distortion to the speakers (the easiest way to blow speakers) . thenstartwith the bass. eeryones ears are different i usually tue the bass to a notch or so below half ao if the radio ges to +12 i wouldput it on 4 or 5. next the mids are usully set at about +2 or 3. then thetrebbel is set a hairhigher than the bass. make this your maximum listenig volume so you dong damage the speakers. Hope this helped! let me know
Sep 15, 2010 | JVC Car Audio & Video
Turning hose one quarter turn does not unlock. Therefore, cannot refill unit.
I've had my steamer for years, so not sure if the models have changed. However, it helps to know where the notches are.
  • Place the steamer with the red on-off switch closest you and the hose/refill cap facing forward.
  • The small notch is kind of between 7 and 8 o'clock (center of notch is about 1/2 inch to the right from the center of the black arrow marked above the "turn to release" on my steamer)
  • The big notch is kind of between 1 and 2 o'clock.
  • The notches on my hose are at the seams. Small notch is underneath the hose, large notch faces forward.
  • Line the front seam of the refill cap/hose between 1-2 o'clock. I pried with a flat head screw driver.
  • After I got mine off I marked the notches, but will still probably store it detached to avoid this in the future! Good luck!
Jun 09, 2010 | Conair Compact Garment Steamer Iron
When I put anyone on speaker, it is really bad, its like a blown speaker. It works fine for regular calls. Whats wrong with it. Thanks
Couple of things that you can try: turn the volume down a notch or two and see if that gets rid of the distortion, another thing is try to gently clean out your speaker (compressed air is best). If that doesn't solve the problem, take it to your local store for them to check it out for you.
Jan 30, 2010 | LG Shine CU720 Cellular Phone
How do I get the speaker panel off?
There are 2 Caps on screws at lower part of speaker grille that holds it intact.
See below image for more details..
Jun 10, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
EQ settings
This setting is a blast,I adapted it from the 10 band "perfect" itunes eq setting. don' t be shy , give it a try...
80hz = (2) or 7
220hz = (0) or 5
470hz = (-1) or 4
1khz = -(-2) or 3
2.2khz= (0) or 5
4.7khz =(2) or 7
12khz= (4) or 9
I have this on my LG tv, however if you need more oomph! to it, simply stick to the same pattern between the two sets above and move each slider up accordingly.
Sep 26, 2008 | Car Audio & Video
Mordaunt Short Avant 309i subwoofer set-up
Lots of ways. To set it up properly you will need a decibel meter, Radio Shack makes a nice one. With the meter volume can easily be set as well as phase. I'm assuming frequency is the crossover frequency, generally set at 80Hz. This one involves some trial and error as I am not familiar with your speakers. Don't know much about the notch filter. A good resource for setting up subs can be found at: http://www.hometheatershack.com/forums/bfd-rew-forum/index3.html
Jun 18, 2007 | Mordaunt Short 309W Subwoofer
Detached cube speaker
I had the same problem.
Step one: pop of the grille with a screwdriver or knife inserted from the bottom so that any marks will be hidden when you get the two halves back together.
Step two: If the speaker is held in by screws, you are lucky. Just unscrew the speaker and remove it. If the speaker isn't held into the case by screws, it is a newer model that is glued to the back cover / box. You can separate the glue with a bread knife or thin screwdriver (I used a paint scraper and thin screwdriver). Be careful to work around all four sides. Also, there is a small (about 1/4" long) plastic bump in the center of each of the four sides that clips into a matching groove in the speaker, so you will have to spring apart at least two adjacent sides at the same time to release the speaker from the cover easily.
Step 3: Once you have the speaker out, remove the acoustic sponge, and sit the bottom half on a solid table. Make sure the rubber gasket between the speakers is seated properly and note the position of the 3 notches in the hole of the bottom speaker cover. Place the top speaker cover in place and insert the white plastic 3 pronged clip though the the hole so that the prongs match the notches. Press down hard with two thumbs and it should snap into place.
Step 4: Replace the sponge and push the top speaker back into the cover. Replace the screws if you had them. Otherwise you can glue it again but the clips are quite solid if not damaged by the removal so you can save some effort the next time it happens by leaving it unglued, and just snapping the speaker into place.
Step 5: push the grille back on.
Mar 26, 2006 | Bose Acoustimass 15 System
Altec Lansing VS4121 Speaker Logo
51 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
