Question about Canon imageRUNNER 6020 Copier
I have iR7105 it gives me a black background with white letters when i adjust deve it gives a print but with the back ground soiled. can you suggest please
I have tied a new carona wires in primary charger and secondary
3 Suggested Answers
  • 39 Answers
SOURCE: i found error in canon ir7105, and i checked
According to the code, the problem is in the laser unit. It sounds like I'm talking to a technician, so I'll approach the problem that way. I personally would first reseat all the electrical connectors on the main PCB as well as the laser unit. Loose connections do sometimes cause codes like this one. The other thing I'd do before tossing the laser unit is to reset the error code because again, codes like this one do come up when the AC power fluctuates from time to time. This is accomplished by entering service mode and then resetting the error . . . your service manual for the ir105 will give you the same method for service model access and the general sequence is the same for resetting the error. Good luck.
Posted on Dec 18, 2009
SOURCE: The printer prints White on Black
try to self clean your printer then test print
Posted on Jun 05, 2013
Print paper becomes soiled
My experience is a soiled copy is that the toner will rub off. If this is what the symptom is you have a heat issue ,
The fixing assembly is not at the correct temperature, or the teflon has worn off the upper fixing roller. thus the ink or toner is distorted when it is fixed to the paper.Of course check the paper for moisture and replace and dont forget to FAN YOUR PAPER.
Apr 03, 2014 | Canon Gpr19 Ir7105/7095 Black Copier Toner
Paint Pro Shop -I am trying to change a logo, I made the back ground transparent and most of the letters from black to white but one letter and parts of the logo wont accept the white with flood fill.
magnify the whole thing as much as you can. Then flood fill the area again. Or use clone stamp tool to copy from the finished colour to the new area. Or use brush tool etc
Nov 26, 2013 | Computers & Internet
Brown background instead of white
You are probably out of ink in one or more cartridges. You need to do a diagnostic print and take the print to the ink supply vendor to get the correct replacements.
Oct 03, 2012 | Kodak Office Hero 6.1 All-in-One WiFi...
Hp 4015 copies are almost black
It can be either:
1. Time to change the fuser
2. The paper is not using plain paper.
I suggest to try first with the type of paper ...
Good luck ...
Apr 24, 2012 | HP LaserJet P4015 Printer
I could not read messages with white letters on blue back ground pl suggest how to convert the text in black color
well did you try highlighting them? as the background is white and the writing is white, possiblity is that you cant see it because white on white = white?!?! amazing right, so if u highlight it you will be able to see them, if thats what your asking??
Mar 03, 2010 | Smith Micro QuickLink Mobile for Pocket PC...
I'm having trouble scanning B&W documents with my Epson V300. The edges of the letters in the text are jagged and hard to read and there is what appears to be a crease or fold in the document when the...
You have two options for scanning text. You may explore both of them and see which is better for you. Either way, you will have to make friends with manually changing the scanning settings, because simple presets often are not suited for every case.
First is to use Grayscale mode, and a minimum resolution of 200dpi. This should give you satisfactory text quality. If you want to print the text afterwards, 300dpi would be even better. You may want to increase contrast, to get the letters more defined and eliminate most of the background toning.
Second is to use Black and White (monochrome) mode, but in this case you need to set the resolution higher, preferrably to 600dpi. Also in this case you will have to play with the Black/White threshold in order to eliminate background "dirt" appearing as black artefacts.
If you scan the documents in order to process them with OCR software, usually the OCR application will give you suggestions on how to set the scanning parameters to obtain good results.
Jan 24, 2010 | Epson Perfection V300 Film Flatbed Scanner
Printing white letters with black background..
you need to select the right tape for your machine. You can't change how it prints except by changing the tape. Brother has many colors to choose from.
Jul 14, 2009 | Brother P-Touch 1180 Label Printer
Brother P Touch 2450 labels print white on black
You can change it by pressing and holding the function (or special) button while you touch the button with a black background.
Jan 05, 2009 | Brother P-Touch 1180 Label Printer
When printing a scanned object, paper is all gray
Whatever scanning utility you are using, set it to Black and white, not grayscale nor colour! regards, babb
May 05, 2007 | Umax Astra 610P Flatbed Scanner
Canon imageRUNNER 6020 Copier Logo
37 people viewed this question
old marine
old marine
