Question about Baumatic Refrigerators
Ice in drain hole in back of fridge
Its always icy in the hole,every morning i pour water down to clear it,the temperature is on 2 1/2 and 0 is off,door properly closed,nothing touching back,not too full
  • 17 Answers
SOURCE: Drain hole in top fridge section flooding and icing up under vegtable storage draws.
maybe you fridge is tilting to far forward some times a fridge needs to lean back slightly only by 5 degs so adjust the foot t the front. this will mke the water flow towards the back and also help keep the doors sealed better
Posted on Dec 10, 2007
stephanos18
  • 144 Answers
SOURCE: the hole that drains water away at back of fridge is blocked
Ok you need to defrost this unit eg unplug and leave all doors open for 48 hours then get some "flexy curtain wire (white plastic coated, used for hanging net curtains) this wire is perfect for getting up or down the fridge drain.
Please rate my advice
Posted on Mar 25, 2009
  • 78 Answers
SOURCE: Kenmore refrig model 10671182101 water leaking in the interior
iced up drain , clean and defrost drain
Posted on May 03, 2009
  • 28 Answers
SOURCE: drain trough at rear of fridge freezer constantly
The evaporator fan may be drawing the water back up the drain hole when it comes off defrost. The drain might be trapping itself or the drain trough might not be allowing the water to travel to the drain hole. Another cause could be condensation and not the drain at all. Door seals may not be working properly.
Posted on Jul 04, 2009
  • 75 Answers
SOURCE: Water leakage from underneath front of fridge
The drain hose is probably clogged with a pea or some kind of food etc. Try pouring boiling water down the hose, or a hair dryer if that doesn't work, or let it warm up until you can pour water down and it comes out into the pan at the bottom. Make sure that the hose is free of dirt etc
Pull out fridge to see the pan, disconnect the POWER..
Posted on Nov 01, 2009
Hi, there is a build up of ice around the drain hole in our built-in fridge. how can we cure this?
This will involve removing your drawers and stuff on shelf above drawers . Heat water to temperature suitable for hot coffee or tea, pour the water down trough, clear ice. Pour water down drain until water flows freely .
If if you have one a slightly less messy way to clear a drain line is to use a steamer. It is safe too.
Mar 08, 2015 | Neff K8524X7 (10.3 cu. ft.)
Refrigerator cooling defrost freezer
Buy a freezer thermometer from any supermarket, it has a guide.
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Nov 20, 2013 | Kolpak SK8-818-CI
Freezer not freezing
Oct 30, 2013 | LG LFX25971ST Bottom Freezer French Door...
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Freezer compressor is short cycling
Sep 06, 2013 | Electrolux Refrigerators
Warning light
Aug 04, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
The hole at the back of fridge is not letting water go down so i have puddles of water running to front of fridge have tried cleaning out but just the same
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 14, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
16 people viewed this question
Top Baumatic Refrigerators Experts
Sal De
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
