Question about Ideaworks Motion Activated Cordless Light -
Motion detector issue
The motion detector stopped working, light stays on.
I want my motion securtiy light to acturally stay on all night. more after animals than people, can this be done?
Usually with mains power motion lights if you switch them on and off two or three times and then back to on, the light will stay on all the time. To put it back to motion, switch off, wait a minute and then switch to on.
This is borne out by this article
Search Results Most motion detectors have a built-in override:
  1. Normally the switch is kept on all the time. ...
  2. If you turn the switch off and on within a second or so, the light will stay on, and this overrides motion detection.
  3. To go back to normal operation, turn the switch off and wait ~10 seconds, then turn back on.
More items...
lighting - How can I override a motion detector light? - Home ...
https://diy.stackexchange.com/questions/.../how-can-i-override-a-motion-detector-light
make motion security light stay on Google Search
Sep 04, 2017 | Home Security
I have a motion detection plug in security light, is it possibel to get it to stay on all the time?
if then light is on all the time what is the point of having a motion detector unit as it is designed to switch on a light when motion is detected
the light switch on when there is no motion but as soon as detected the light comes on primarily to light the way for you or to scare off intruders
having the light on all of the time is a waste of energy
Sep 04, 2017 | The Home Security
As per request. re: reset/fix indoor motion detector.
on all the Honeywell or Ademco wireless motion detectors I have worked on the light will not come on with the cover in place, it is set that way to conserve battery life. If you want to be sure it is working properly arm your system and wait at least 4 minutes before walking in front of he motion then walk in front of it and see if it trips the alarm.
May 05, 2014 | Honeywell Ademco Apx32en Alarm System...
Cooper ms34w wont turn off stays on night an day without movment
Have you had a look at the underside of the motion detector the should be some things for you to a just it with
Mar 25, 2014 | Cooper Lighting Flood Lights. 180 Degree...
I have this light for 2 years with no problems at all. recently, it seems that the "left side" of the sensor stopped working. (If I walk right in front or in the right side, the lights will come...
  1. Locate the sensor on the motion detector. The most common problem with a motion detector is a sensor that is obstructed or dirty. Remove any dirt, grime or anything else that may be blocking the view of the sensor. If you need to actually touch the sensor itself to clean it, use a soft cloth or cotton swabs.
  2. Determine if the motion detector has electricity running through it properly. Connect an electrical meter to the wires from the sensor itself. If electricity is indeed running to the sensor, you likely have a broken senor. If there is no electricity making it to the sensor, your motion detector has an electrical short. In the case of an electrical short, you will need the help of a professional electrician to fix it.
  3. Visit a hardware or supply store to buy a replacement sensor
Thanks for understanding.
Nov 16, 2011 | Heath Zenith All Metal Motion Sensor Light...
Hi my question is motion spot light has has two black wires one from each light and two white from each light and one red from the motion detecter which is connected to the black wires there are two wires...
The red wire from motion detector connects to both of the black wires from the lights. The black wire from the motion detector connects to the incoming black wire from the switch or source. The white wire from the motion detector connects to both of the white wires from the lights and to the incoming white wire from the switch or source (all white wires are under one wirenut).
Dec 18, 2010 | Home
I need to reset my outdoor lighting == motion detector lighting after a bulb blew. The light just stays on -- no dimming. Is there a catch to how to reset the lighting/
hold down the reset button and stay behind the sensor. Mine does this exact thing in lightning storms it may take a few tries. Good Luck
Nov 09, 2010 | Garden
Wiring diagram 3 way motion detector switch I want the motion detector to be in the hot line box, and I want a regular 3 way to turn the light on from the load box. So far I can only get the motion...
Sorry, but you need one extra wire between the switches to wire "the opposite configuration" that you want :-(
That means going into the attic and pulling another cable :-( I can walk you through it if you are willing to do all that work.
The only other solution would be to purchase the commercial version of that motion switch, which would also require a sensor at _each_ switch location :-(
Jan 02, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
My motion detector switch stays on, lights won't turn off. How do I reset the switch?
Hi MBE,
Most motion detectors have sensitivity and duration adjustments. Others have test modes.
Since the model is not specified, I can't tell you where to look.
You will know it when you see it though.
Best regards
Mike
Dec 05, 2009 | Pass & Seymour Electrical Supplies
Ideaworks Motion Activated Cordless Light - Logo
79 people viewed this question
Top Ideaworks Home Security Experts
Lawrence Oravetz
Are you an Ideaworks Home Security Expert? Answer questions, earn points and help others
